Question about Toshiba Satellite A75-S226 Notebook
Computer shuts off
Hi. i bought my computer august 2004. i never had a problem with it until early this year. it started to suddenly turn off. i just read a blog and found out that it was some heating issue. i have tried putting a fan behind it, propping it up about an inch from the table - but all that failed. will toshiba still do something about this?
  • jimtow Jan 01, 2008
    I have exactly the same problem with the computer shutting down suddenly. It does appear to be an issue connected with overheating as the surface of the computer above the exhaust vent does heat up. It was getting so bad that it was shutting off every few minutes.
    I did spray compressed air from a can through the air intake vents and a considerable amount of dust was expelled. The problem was much improved. However, only a few weeks later the problem has resumed although it does not happen as frequently.
    Does anyone know of a more permanent solution or repair??
Put it on a cooling plate with fans available at most computer stores. Solved the over heating
Stopped the overheating but now the battery will not charge completely and the plug for the AC connection is finicky four years later.
Posted on Jan 24, 2008
  • 85 Answers
Use can air and shoot it thru the vents.
Posted on Nov 12, 2007
Well everything said is fine, but it is a manufacturing defect...two cooling fan at the surface of the laptop works as a vacuum everyre singly dust it can and closes the vent.
In a short run you can open and clean and do what you want, but in longer run it will destroy the power supply plus/or the motherboard. If you go to a local repair store they will replace the motherboard and charge you for it, same thing happens if you go to Toshiba repair centre. Technically, since it is a manufacturing defect they (toshiba) should replace the parts or call back the notebook.
Even if you replace the motherboard the issue has not been solved, this will happpen again and you will keep paying for the repair.
Posted on Feb 27, 2008
Car shuts of suddenly while driving. Starts back up after 20 minutes.
When the gas-cap is plugged, you build up vacuum in the gas- tank and cause the gas flow to stop.
Use premium gas only, ETHANOL in the mix is attracting moisture/water which is part of the problems.
Jun 26, 2015 | Cars & Trucks
I have 2005 toyota prius replaced both battery's were bad and it was hard to get started and it finally started for a minute and shut off and now all indicates are back on closed sircut code's
I have a 2004 Prius, purchased in August of 2004, ... I just replaced mine after 5 years since my car would not start if left ... Turned out the fault was in the brake light switch. .... I open and close the door to make sure lights are all off. ... Toyota dealer DOES know that you have bad battery.
Feb 19, 2015 | 2005 Toyota Prius
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Display problem
sounds like the internal video card is dying . have the service tech this out.
Mar 10, 2009 | HP Compaq Presario CQ50-110US Laptop
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Viewsonic 19
But of's can. Asked him if the LCD Monitor got any power (a green light on) If it has, switch cables, if it have a DVI connection used that cable and see if it work. Still had a problems...Then the backlight is burnt out. Have a nice day!
Sep 07, 2008 | ViewSonic VX924 19" LCD Monitor
Automatic shut off of pc
There is a CD tool called "Ultimate Boot CD" which can be downloaded at On this CD there are quite a few tools that you can use to test your RAM, CPU, Hard Drive, etc.. for problems. Just boot up with this CD and select the corresponding testing program to use. Test each thing until you find the component causing the issue.
Aug 17, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Monitor Suddenly Shuts Down
you should download and install the software for your computer model that controls the functions like increasing & decreasing screen brightness, switch between screens etc. Try reinstallimg the OS using the recovery CD ROM that came with your computer
May 17, 2008 | Dell Inspiron 1150 Notebook
Will not open
Take it back to the store, if it is still under a year old.
If they fob you of with some bull just ask to speak to the manager, if he isn't in or wont help ask for the area manager.
Dec 30, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Toshiba Satellite A75-S226 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
