Had a transmission job and steering wheel radio volume channel and cruise controls are not working. Also the SRS Driver Airbag light on,..?
SOURCE: SRS light stays on
This is most likely a wiring issue in the steering column. I advise you not to attempt to repair this on your own unless you are an experienced mechanic. If you do be very cautious as the airbag wiring runs through there and can be a very dangerous mistake.
SOURCE: steering wheel buttons dont work on my 2004 accord
Check the fuses and relays. Generally if only 1 accessory doesn't work, the problem is with that particular accessory. When ther are several that don't work, check fuses and relays.
