Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Western digital external hard drive
So I accidently pluged a higer voltage converter into my western digital hd and have most likley cooked somthing inside besides my actual drive. My guess was a capacitor or some other componet. Is this fixible or shoudl I chalk it up for a loss? I still get power when I plug it in with its normal converter, but all it does is flash the on "light ring" on the front. I pulled off the housing and nothing seems to be burnt of broke, but then again I am not a small electronics guy. any Ideas?
  • UXO21 Nov 12, 2007
    I have tried the original power source and hod no luck with it. I am not technical enough to open up my pc and swap hard drives, or at least had not considered that. Is that very hard? Do you think they have the same connection. I have a hp pavillion a1350n. For the WD to work I have to plug it into the outlet and the computer via the usb port. I really appreciate you getting back to me so quick.
  • UXO21 Nov 15, 2007
    Hey I have not had a chance to pull my pc hard drive yet but I will be trying it soon. I really really appreciate your help so far, you hae been very helpful. I will let you know how it turns out soon. Thanks again
  • 537 Answers
I would try the correct voltage adapter and see if you can get it working.
You could remove the hard drive from the myBook drive and plug it into a PC to see if the hard drive is damaged or if it is the electronics/pcb that is inside the myBook drive.
You might be able to salvage just the hard drive (use it internally) and throw away (or keep for parts) the rest of the case/parts of the myBook unit.
Mike
Posted on Nov 12, 2007
  • Mike McWhinney Nov 12, 2007
    It is not too difficult to remove the hard drive from the myBook drive.
    Just make sure that if it is an ATA drive (my guess it probably is a PATA and not a SATA), it should work in about any PC, especially a newer one that will natively work with a hard drive as huge as a 320GB one.
    Mike
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Unrecognized
some proble was in USB socket of your external HDD...poor contact...
try to use another HDD enclosure to use with you HDD..
that problem occur due to pluging in and out several times...maybe the connector was damaged...hope it helps..
or try another PC again...some problems are not detected due to virus in PC...
May 25, 2010 | Western Digital Passport WDXML800UE...
External hard drive problem.
1. The usb cable could be defective
2. The usb port could be malfunctioning
3. The drive could be defective.
Try using another usb port, or try adding a PCI card usb ports
Nov 07, 2009 | Western Digital My Book Essential Edition...
Accidently uninstalled Western Digital program
google western digital and dowload the drivers again, then reinstall from disc if you have one! (do this with the drive un-plugged) when you then re-boot and plug it in all should come right!
Sep 27, 2009 | Western Digital Passport 320GB External...
External Hard Drive
If you plan to store movies on the HD, better buying a 1TB hard drive. WD Mybook is one of the best external HD.
To rip and store DVD movies into the hard disk you will need a specific software, like the ones below.
DVD Converter - convert DVD video to AVI/MPEG/DIVX files
Freeware converts DVD AVI MPEG WMV RM to MP3 or iPod Video
Movie2x Freeware DVD Converter Download
DVDx (freeware from labDV)
Jul 28, 2009 | Western Digital My Book Essential Edition...
Linux and Western digital external HD
should be no problem at all
use fdisk to see and format the drive
Feb 05, 2009 | Western Digital My Book Home Edition 500...
Wd external hd
not possible. i suggest 24/7 antivirus monitoring.
Feb 15, 2008 | Western Digital 320GB MyBook External USB...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
250 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
