This link might help: https://www.google.com/search?hl=en-US&q=how+to+fix+Miele+w2104+washing+machine+Rinses+light+flashing&spell=1&sa=X&ved=2ahUKEwjboeG0yZDyAhVJT30KHTy-DHwQBSgAegQIARA0&biw=1366&bih=625
Hi dear. Your machine may have one of the three factors playing up.
1- Tacho generator or it's plug on motor
2- Motor carbon brushes
3- Power/ electronic module faulty. Thanks.
There are two main causes for this failure:
- carbon brushes are worn
- electronic is defective
The exact solution is depending on the model of your Miele washing machine and works for all modules that start with:
EDRU, EDSU, EDSTU, EL, ELP, EDPL,
you may visit youfixit.eu for a solution. Miele repair Address and payment information
Most units have a recirculating pump, and an output (drain) pump.
If I were you, I would disconnect it, drag it outside and turn upside-down (remove everything internal first)
Take off the drain pump and check over, then check the main pump motor for free rotation first.
Also clean both those, and check condition of hoses/ carbon brushes on main motor while you're there.
Doing this full service now should give you a long run without problems.
My guess is the main motor seal may have leaked a very little, allowing the spindle to sieze. Freeing it and applying light oil with regular use should be ok.
Replace carbon brushes if worn to save hassle later - they're cheap.
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
