Question about Samsung DouCam SCD-5000 Mini DV Digital Camcorder
The swivel mechanism fall a part....what to do?...haw?
0 characters
1 Points
I don't know how to play videos on my dr. Tech hddv5520 camcorder
use the video cord that came with it,or buy one,
This digital camcorder has a flip-out LCD screen that swivels for front and back viewing. A five megapixel lens records at 30 frames per seconds for high-resolution fun. Includes 2GB Micro SD card.
  • Color options: Red
  • High-resolution, full-motion VGA quality
  • Records at 30 fps
  • 5MP CMOS sensor for extra-sharp images
  • LCD 2.4-inch TFT LCD monitor
  • Display swivels 270 degrees with front and back rotation
  • Omni vision 5-megapixel CMOS sensor
  • Zoom: 8x digital zoom
  • Power on the go with two AA-size batteries (or rechargeable AAA battery)
  • System requirements: Windows XP/Vista, Mac OS 10.x or above
  • Dimensions: 4.25 inches deep x 1.25 inches wide x 2.25 inches high
Package includes:
  • HDDV5520 5MP 2.4 inch LCD Digital Camcorder
  • Two (2) AA alkaline batteries
  • 2GB SD card
  • Video and USB cable
  • Camera pouch
  • Wrist strap
  • Quick start guide
  • CD, user manual, software and drivers
Jun 30, 2015 | Video Cameras
Common problem with this camera, the codes reflect reel sensor errors. The first thing to check for is when you open the cassette assy look inside to the right is there a black rubber kinda tall wheel like roller? The pinch rollers are known to fall off of their posts in this model. If the pinch roller is there then the mechanism needs to be replaced. Hope this helps. email me for service if needed.
Jul 27, 2011 | Sony Handycam DCR-TRV16E Mini DV Digital...
Haw to dawnload manuals of GZ-MG730
Please click the following link to download the manual.
If you feel that I have helped you, please rate my answer with helpful.. Thank you
Jan 05, 2011 | JVC GZ-MG730 HDD Camcorder
Haw to oprate canon xl2
You can download the manuals for the XL2 here.
Feb 05, 2010 | Canon XL2 Mini DV Digital Camcorder
Sony DCR-SR62 screen rolls continuously
HAd the same
It's a flex wire connecting LCD with camcorder. got from the repair shop. did it by miself workes like new. it'very common in this kind of sony.
Aug 07, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
The swivel screen displays an image until it is partially opened.
It is the flexi/ribbon cable that runs from the camera body to the screen that is at fault. It has got broken tracks.
It might work occasionally when the tracks are touching but after a while it will only get worse. A new ribbon cable is needed, which should be a straight forward job for a repair shop or if you can get the cable yourself, an electronics wizz kid !
Jul 26, 2009 | Panasonic Video Cameras
Please tell me haow can a set my JVC GR-D240 as a
connect the firewire cable - MSN Messenger detects it. Apparently there are issues with Yahoo Messenger. WARNING: you will need 512k+ upstream, you're pumping DV quality video at 30fps rather than standard webcam resolution of 320x240@12fps!
Jul 15, 2009 | JVC GR-D240 Mini DV Digital Camcorder
Bad colors on Swivel LCD Display
it is more than likely the flex in the hinge for the lcd. the hinge might need changing. suggest the camera be taken to a qualified panasonic tech.
May 31, 2008 | Panasonic PV-DV103 Mini DV Digital...
Swivel lcd screen
dam that suks for u i used alot of money on that camera
Jan 02, 2008 | Vivitar DVR 530 Flash Media Camcorder
JVC Camcoder GR-DX77 has no Picture in Record Mode
Definitely, don't use Sony miniDV tapes! The fault occured because of rough handling of the mechanism during cassete insert or from dropping the camera.A guide arm inside the mechanism is deformed and the mechanism can be changed in whole for this.Contact a JVC authorized centre.The price for this can be half the price of a new camera. After all, it's your fault. This is a good camera if you know haw to handle/ use it!!!
Sep 15, 2007 | JVC Handycam GR-DX77 Mini DV Digital...
Samsung DouCam SCD-5000 Mini DV Digital Camcorder Logo
18 people viewed this question
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Chris Hunt
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
