Question about RCA TruFlat 27F520T 27" TV
Tv turned off while wathcing, can turn back on but no picture.
I was watching Tv and it turned off by itself. The only way to turn back on was to un plug it and plug back it. The power came on but no picture, black screen only. Channels dont change and only able to turn off TV now by unplugging.
  • 2 more comments
  • junior23 Dec 19, 2007
    while watching the t.v. just suddenly turned off. i turned it back on and it came on but no picture appeared.....i am not able to change channels or anything..........and it keeps making this weird squeeking....i tried mto unpluging then pluging back in but that didnt work...still the same result
  • jerryrose Dec 29, 2007
    tv turns off by itself and sleep timer is off
  • heavynhailey Feb 11, 2008
    I turn my TV on,the picture is perfect as well as the sound,but after about 5min. of watching it,it shuts off .If I immediately try to turn it back on ,it remains blackout .Although after a while of waiting I can turn it on again, but it repeats the same cycle.
  • Anonymous Feb 16, 2008
    tv turns itself off, i can be watching tv for awhile then it will turn itself off, I unplug it then wait it go back on but after 5min or even 2 minutes it turns itself off !!!!!!!!!!!
Posted on Jul 06, 2008
  • 47 Answers
This sounds to be a faulty flyback transformer, as it heats it gets a shorted winding and the protection circuit shuts the set down to avoid big sparks.
this is not a user solvable problem unfortunately and i would recommend taking it to an electronics repair shop and getting a quote for repair.
Posted on Feb 18, 2008
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
TV freezes up when turned to channel 33-1
I had the same problem. I also use rabbit ear antenna , no cable or satellite. I was watching ch. 33.1 and the tv turned off by itself. The remote wouldn't work. The power on/off buttons on the side of the tv wouldn't work. I had to un-plug the power cord to turn the tv off. The tv forze on ch. 33.1 when I turned it back on.
I called Vizio, they told me they received hundreds of complaints from people in Texas complain g about these problems.
I was told to un-plug the antenna cable and re-plug it. I did this plus I re-scanned all channels. The problem has been solved, the channel (33.1) no longer freezes and the tv doesn't turn off by itself.
Hope this helps.
Aug 22, 2009 | Vizio VW32L 32 in. LCD HDTV
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
TV only 2 months old ceases to work
I think it is the EHT for some reason it blew off for you. You got a miniature picture after you turned it on again because it was partially damaged and then it blew off completely. It can be fixed from a competent person.
Jan 07, 2009 | RCA TruFlat 27F520T 27" TV
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
TV turns itself off
Sounds like you need a new power supply board
Nov 26, 2007 | Panasonic PT-47WX49 47" Rear Projection...
*** I have to configure Colors with each power on. ***
The six controls you appear to be adjusting are the screen and focus controls for each of the three picture tubes. These usually only have to be adjusted as each picture tube ages or when replaced. You may either have a defective "focus block" i.e. the black box you have been adjusting, or the CRT's themselves may be going bad at this age. You will probably be money ahead to just replace the TV with a new HDTV set. At 13 years old, it shouldn't have much life left in it anyhow.
Dec 29, 2006 | RCA P46924 46" Rear Projection Television
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
RCA TruFlat  27F520T 27" TV Logo
156 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
