Question about AEG Lavamat W1450 Front Load Washer
AEG Lavamat w1450 electronic.
Cant get machine to work, shut door and select wash program, nothing happens, all the lights come on but when the door locks, lights start to flash, is this the program board.
  • 2 more comments
  • skarakatic Jan 08, 2008
    1. By the end of washing (after the centrifuge) the water is still in the mashine (the filter is clean).
    2. By the 40°C washing the temperature is rised to the 90°C.
    3. And if it possible to get a copy of operating instructions for this mashine.
    The product INFO:
    E-Nr. 605423055
    Type P 6338460
    220-230V-50Hz 2750W
    F-Nr. 065000869
    I thank you in anticipation.
  • Anonymous Mar 19, 2014
    Dear sir,
    When I start the washing machine all its program lights are blinking and nothing is starting. what could be the problem. Please suggest solutions that can be done by me.
  • Anonymous Mar 25, 2014
    power is ok but nothing happens when door is closed and start button is pressed - no alerts shown on display
  • Anonymous Mar 30, 2014
    Manual to drain the washing machine, think something mechanical went wrong. Murky water stuck in the machine with washing.
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
Aeg lavamat w1450 will not light up..... power is on
many times it turns out to be the door switch has failed .
Jul 12, 2016 | AEG Washing Machines
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts to flash. Door indicator light then goes from...
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
Jan 07, 2011 | AEG Lavamat 12710 Front Load Washer /...
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
Can I use hot water supply only on my AEG Lavamat W 1159?
A valid point but unfortunately your machine is programmed to take both and will register this as a fault.
This is probably not what you wanted to hear but please dont shoot the messenger.
Jan 22, 2009 | AEG Lavamat W1450 Front Load Washer
How to re-fit front rubber seal on Lavamat
The seal is mounted to the outertub with a big spring, an on the frint with a plastic ring. Not very easy.
Jan 20, 2008 | AEG Lavamat W1450 Front Load Washer
40C cycle stopped with 12 mins on display - now nothing works
Press "end of cycle" & wait for 2 minutes then try the door, do not force the door........................ If problem persists go to your model above & click on your model number & look for solutions....should find something.
Jan 12, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 72640
Probably the motor is broken. Or the tachometer is loose from the motor.
Dec 26, 2007 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Oct 24, 2007 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat W1450 Front Load Washer Logo
450 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
