1993 Cadillac Eldorado Logo
A
Anonymous Posted on Feb 18, 2015
1993 Eldorado Cadillac ac compressor won't take freon. Display says compressor off, low refrigerant. How to bypass computer? Can compressor relay be jumped using paper clip? Which holes? to
1993 Cadillac Eldorado electrical wiring
Roxanne
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 18, 2022
Roxanne
Contributor
Level 1:
Answers
Questions
0
Helped
563
Points
Disconnect battery and upon reconnecting start releasing freon
jeff5may32
Level 3:
  • Cadillac Master 1,258 Answers
  • Posted on Feb 18, 2015
jeff5may32
Cadillac Master
Level 3:
Answers
1258
Questions
0
Helped
375625
Points
5289
Grab some refrigerant gauges and take readings. If the low side has more than 40 psi or so of pressure, the low limit switch will close and allow the compressor to run. If there is indeed low pressure causing the compressor not to run, you will need to flush the system after eliminating the source of the leak. If the a/c compressor has never been changed, it is probably the source of the leak.
I changed my as compressor and now it will not come on
You would have to jumper the low pressure sensor to engage the clutch to be able to put freon back into the system.
You would also have to clear the codes from the computer too. There should be a code saying the system is low on freon and that would block the compressor from having power.
I'm getting an error code that states "Refrigerant Low - AC Off" or something real close to that. The compressor won't come on to take freon without clearing the code. I have had it...
Hi Bill,, don't worry about the codes, any shop that you take it too will know what to check and how to get the codes if they need them,, Most already know how to fix your problem, which would be a day to day thing for them,
AC runs for a few miles,then says it's low on freon and the compressor kicks off. It is not low on freon and I had a mechanic working on it for months. New compressor, dryer, orface tube, etc. Can you...
What is the pressure when the compressor running? should be between 25-35 PSI no more then that cause it wont get cold and might even say low on freon.
1helpful
3answers
MY 2001 ELDORADO AC WON'T ACTIVATE AS IT ADVISES THE REFRIGANT IS LOW. I TRIED TO ADD REFRIGERANT BUT THE COMPRESSOR WON'T COME ON TA INHALE IT SO HOW DO I GET THE REFRIGERANT IN? THANKS -JWB-
Hi, the way to get the compressor to come on is to short the connector to the pressure sensor on the return line. The sensor is along the same line you were trying to charge on. Just remove the connector and use a large paper clip to connect the terminals inside the connector. Please let me know if you have more questions, and thanks for using FixYa.
After replacing freon ac to new coolent computer will read that the collent is low and shuts down the compressor. How do I correct this or how do I reprogram the car's computer?
Disconnect the negative battery cable for 25 seconds and put it back on,then add more freon,unless you know you have put in enough,if so,remove freon,and remove the orifice tube and replace it.If this was helpful,please rate,thank you.
A/c compressor not working added freon but it
Either the system is still low of freon,or the sensor (one of them)is bad.The sensors are on the high side of the system,liquid line.If you will get on chat,I can help you with this,it will take a while,I will need to know how much freon was added.And what the system is doing,is the ac clutch engaging,etc?Ask for ronicon,when you click on chat with,type my name in,roniecon,with your text,that you are writing .
1helpful
1996 cadillac deville compressor stopped, new compressor and dryer put on, but unit will not accept freon. Please help.
Sometimes, you have to start the vehicle, turn on the AC (Hi setting), and jump across (bypass) the low side pressure switch - to allow the compressor to start running and draw the freon in through the low side - make sure your fittings are correct and otherwise - Did you pull a vacuum on the system before you attempted to add refrigerant? I would highly recommend it - removes air and moisture....
4helpful
'99 cadillac eldorado, Northstar engine w/AC problem
Have you unhooked the battery since you put the freon in? If not, do it.
2000 Caddilac Eldorado Compressor won't kick in
Hi, oK ASSUMING THERE IS THE PROPER AMOUNT OF FREON IN THE SYSTEM (2.0 LBS) THE SYSTEM IS PROBABLY LOGIC LOCKED.THIS CAN HAPPEN WHEN THE CADILLACS HVAC CLIMATE CONTROL HEAD GETS CONFUSED,USUALLY AFTER A RECHARGE.HERES WHAT U CAN TRY.REMOVE THE NEG BATTERY CABKE FOR 1 MINUTE,THEN RECONECT IT,START THE CAR AND PUT THE AC ON (60 DEGREES FULL FAN) THAT SHOULD DO THE TRICK HOPEFULLY. THAMKS RAY.
1helpful
2answers
1997 Deville ac compressor locked out - low
70 psi static does need a charge.find compressor relay, jump relay and compressor will start. add refrigerant,replace relay and a/c should work fine
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
