2003 Kia Sorento Logo
A
Anonymous Posted on Feb 17, 2015
2003 sorento 3.5 cranks won't start code 300 302 304 306
Richard Brooks
Level 2:
Sergeant:
  • Kia Expert 242 Answers
  • Posted on Feb 19, 2015
Richard Brooks
Kia Expert
Level 2:
Sergeant:
Answers
242
Questions
Helped
91087
Points
637
The code 300 is a Random/Multiple Cylinder Misfire....a 302 is Cylinder # 2 misfire detected. ..and the same for 304 and 306..being 304 is cylinder 4 misfire and 306 is cylinder 6 misfire...All these at the same time normally is a faulty coil pack..,and or faulty coils...spark plugs.,plug wires.....It should be running horribly or barely ....However it could be internal losing compression.....It could just need a good tune up.....Disconnect battery before changing coils,wires..,or plugs in order to clear the fault codes.....
2006 Kia Sorento. It cranks but doesn't start?
Sorento cranks but wont start - Kia Forum
kia-forums.com https://www.kia-forums.com > threads > sorento-crank...
May 8, 2016 - You can try resetting the fuel cutoff switch. It is located near the windshield, passenger side behind the reservoir under a small black rubber ...
Engine turns over but won't start, HELP - Kia Forum
Apr 15, 2009
Help, Kia cranks but won't start!
Mar 6, 2008
Cranks but won't start? - Kia Forum
Sep 3, 2012
Sorento runs then won't start for several hours - Kia Forum
Aug 30, 2011
More results from www.kia-forums.com
My Engine Cranks but Won't Start (6 Reasons Why)
AxleAddict https://axleaddict.com > auto-repair > My-Engine-Cra...
Mar 28, 2023 - Answer: If the engine cranks but won't start, it is turning over. Start by checking that you got good spark and fuel pressure. If the problem ...
I have a 2006 Kia Sorento LX 3.5 l engine I replaced the
JustAnswer https://www.justanswer.com > Kia Troubleshooting
Apr 18, 2022 · 1 answer
If the fuel pump and starter do not have any power, you need to start by checking the fuses and checking for codes in the computer using a ...
How to fix 2012 kia sorento camshaft sensor
replaced crank and cam sensor [Archive] - Sorento Nation - KIA ...
www.sorentonation.com/forum/archive/index.php/t-913.html
20 posts - ‎6 authors
replaced crank and cam sensors put back together cranked up very rough idle some tapping any ... 12-17-2012, 12:24 AM ... It's a 2006 3.5 Kia Sorrento. ... I found theproblem the SUV has a aftermarket alarm and remote start system I tripped ...
Kia Rio Crankshaft Position Sensor Replacement - YouTube
? 4:44
https://www.youtube.com/watch?v=hihQxMWuSFY
Mar 21, 2014 - Uploaded by Jason Roush
While looking for how to replace a Kia Rio crankshaft positionsensor, ... is on and i have a P0340 code, think this is theproblem? kia rio 2002.
Kia Sorrento/Sedona: 3.5 Litre Engine/Timing Belt/Crank ...
? 20:23
https://www.youtube.com/watch?v=CjaD_zYPrUA
Mar 29, 2014 - Uploaded by JamieJones TheCarMan
Repair and/or Replacement tips for timing belt, crank sensor,cam sensor, water pump and drivebelt ...
Crankshaft position sensor - 2003 Kia Sorento - RepairPal
repairpal.com > Questions > Kia > Sorento > 2003 Kia Sorento
L have a 2003 Kia Sorento, sometimes it will just turn over but won,t crank. after a while it will start up. or l can be driving down the road and it will start poping and cut off, and won,t start.it does...
It will be a position sensor problem Check the air gap and check that the censor rotor is tight and that there is no material getting in the air gap causing a problem
2helpful
2003 kia sorento wil turn over but won,t start. after a while it will start up. l can drive down the road and it will cut off. after awhile it will start back up l checked the code and wasn,t getting any...
This is almost for sure the fuel relay. I do not know where it is on your car but I would look for it to be by one of the back wheels where road junk can get to it and corrode it. Once found not very expensive and very easy to replace.
1helpful
05 Kia sorento won't start replaced battery two
Do you have fuel pressure and spark to the plugs ?
2003 kia sorento check engine light came on car died, It cranks but won't start what is wrong??
Could be lot of reasons but check the engine light code to see whats wrrong then you can start from there. Good luck
1helpful
3answers
2003 Kia sorento starts and then won't start
change your fuel filter. it seems youve done all the major actions but havent tried the common fix.
7helpful
There is a black rubber button reset switch right next to the air box, press it sounds like the problem i had its a fuel pump reset (just in case of a wreck it kills the car) but there is a tiny ball in there and if it is rattled a little too much it will fall and you need to press the black looking button to reset it....took me like 4 months to figure it out
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
