Question about Canon PIXMA iP8500 InkJet Photo Printer
NO PRINT HEAD
Printer will go through the motions of setting up when you first turn it ON , then it displays the message " No Print head ". It won`t print anything at all . The print is about 2 years old and I`m wondering if it just needs a new print head ?
Let me know ASAP !
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
First remove cartridges and remove print head and make sure the contacts on back of head look clean. I use fibreglass pen and give clean if in doubt.But be very carefull cleaning. But maybe not seated correctly.? If you pull the print head out and do another test does it come up with same message.?
Try again and see what you get. Still worth replacing head if faulty as where else can you get a 8 ink printer. Unsure what head costs.
Posted on May 19, 2008
How do I clean Print heads
it is one of the very sensitive part in printers so don't touch the printer head nozzels if you want to clean printer head go to tools or settings and go to clean printer head option it is the only way for clening ph safelly option.
Jun 28, 2014 | Canon PIXMA MX340 Wireless Office...
Tip
Disconnect the power. Open the cover of the case and make sure the 2 black and 1...
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
4) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
5) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
6) Try to feed paper manually (using the paper feed button).
Else,
7) Before re-connecting the printer to the computer, uninstall the printer driver and restart the computer.
8) Re-install the printer driver.
on Nov 17, 2008 | Epson Stylus C88 InkJet Photo Printer
My printer HP photosmart plus B210 series displays error message
>> Remove the print head and gently clean the head.
>> Check is there any obstructions on it.
>> Turn Off the printer for 2-3 minutes and turn On.
>> Re-insert the print head and check the status.
It may help.
Nov 25, 2013 | Computers & Internet
I have Zebra P330i printer, have done the cleaning using short and long cards. Display shows "Ready". On printing using color ribbon, the messages (Printing Yellow, Printing Magenta...)appear on...
Knowing that you were able to complete the proper cleaning procedure using the short and long cards, and the printer is on ready status, try to change the ribbon and test. Make sure the card is properly inserted with the magnetic stripe on the top facing down. Also make sure that the ribbon is properly loaded. There should be an instruction on the cover for its proper orientation.
If it still does not print, make sure your configuration on the printer is set to the proper type of cards HICO or LOCO and the ribbon type is properly set to YMCKO for color. Also, check if you have enabled mag stripe encoding or if you don't need to have it enabled. Enabling means that the printer will check for the mag stripe if its good or bad. If bad the printer will reject the card.
Do a self test print by following the below. 1. Set the printer's power switch (on the back of the printer) to the OFF ( O ) position. 2. While pressing the Printer's front panel button (next to the LCD display panel), switch the printer ON ( ' ). 3. Hold the panel button until the LCD display panel reads "SELF TEST". 4. Release the panel button, and the test card will print
If no prints, observed for any mechanical errors on the printer. Normally mechanical errors are detected by the printer with corresponding error message.
If none of the above works then you might have a print head problem. You may attempt to clean it by following below. Else if it does not help then have your print head replaced.
A cleaning using the Cleaning Cards usually suffices. However, a separate Print Head cleaning can remove more stubborn deposits when print anomalies persist. To avoid deposits, only use foam-tipped swabs. 1. Place the printer power switch in the OFF ( O ) position. 2. Open the Main Cover, release the Print Head Carriage, and remove the ribbon. Leave the Print Head Carriage in its raised position. (For details, see Chapter 2.) 3. Clean Print Head by moving an alcohol-moistened swab tip side-to-side across the Print Head elements. Only use moderate force. To re-order swabs, please refer to the Media List on the Windows Drivers and User Documentation CD supplied with this printer. 4. The swabs can also be used in a similar manner to clean the optional magnetic encoding head.
Jul 12, 2011 | Zebra P330i Thermal Card Printer
When making On, the printer displays a message W7100
this error code, stand for print head trouble.
You can try following:
1. Visual inspection:
Press down the BJ print head set locking lever to set it in a proper position if the
lever is pulled up.
Install the BJ print head if it is not installed.
2. Carriage unit
Visually check and replace faulty BJ print head set components or BJ print head
locking lever.
3. Replace the head controller.
4. Replace the system controller.
Hope that helps!
May 30, 2011 | Canon BJ-W9000 Copier
Error message 07,010.43:24426
The print head is not moving freely.
The print head wiper may be tacked to the print head, or the print head block may be filled with ink causing the print head not to pivot.
Jan 21, 2010 | Xerox Phaser 8400 Laser Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Printhead (R), Check Printhead - Canon IPF5000
that confirms Right Print head is may be Out of Ink or near to low ink level.
check whether there is any option to Disable Alerts in printing preferences..print settings >> printer settings
Feb 18, 2009 | Canon imagePROGRAF iPF5000 InkJet Printer
THS Error on warrantee printer tally serial printer
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Apr 09, 2008 | Tally Matrix T2280 Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
197 people viewed this question
old marine
old marine
