Takeing all screws out of back side but do not want to brake housing is it glued together on front seam
SOURCE: Dewalt Radio
take all screws out of front perimeter, then there are 2 screws on the back at the bottom right and left you have to look close these screws are deep.
SOURCE: DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
SOURCE: dewalt dw911 radio
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP)......works great now!! Many thanks to all of you who posted suggestions on this great website!!
SOURCE: radio works on ac power but not on batt power
"Radio works on ac power but not on batt power AA batt seams to be ok" The AA battery is only for the radio memory and clock. Have you put a battery from your drill in the radio? if so check fuse inside radio.
