I have tried to download and install from the internet but it does not work. no error messages, does not down load, just times out. no access to the internet on that system.
Try system restore. it will sent the system to an early time before you deleted the drivers.
click windows logo>>search bar type>> system restore>>>
then select system restore,then when is opened.. select older/more
system restore check point..>>> select the check point before the incident.....
this will leave your pc in the state it actually was before you erased the drivers... let the computer finish the restore,it will reboot by itself. good luck
SOURCE: need a scsi driver for maxtor 6L080M0
I am sorry to inform you that is not correct. If I am not mistaken this is your drive.
Maxtor DiamondMax 10 6L080M0 80GB Hard Drive
Serial ATA-150, 7,200 RPM, 8MB - MPN: 6L080M0
Look at this link, it should help:
http://computeraccessories.suite101.com/article.cfm/sata_serial_ata_hard_drives
SOURCE: ntkrnlpa.exe issue
sorry, wish i could help you out, however i dont have any experience with computers what so ever, try resubmitting your request to one of the other experts i am sure one of them will be able to help you.
SOURCE: Windows Xp on Intellistation Z Pro type 6221
A restoration disc is not a conventional Windows OS disc (and vice
versa), therefore it often cannot be used as if it were a true Windows
disc. The restoration disc includes the OS, but it also includes every
driver and other software product that came with your system. If
Windows were the only item loaded on your system, then a Windows disc
could serve as a restoration disc, but these days, using a typical
restoration disc is an all-or-nothing process.
A restoration
disc is your ultimate troubleshooting tool. Suppose that your copy of
Windows becomes damaged from a virus or key applications become
corrupted. Symptoms such as instability, crashing, indecipherable error
messages, and impaired performance are extremely hard to diagnose by
yourself—even if you have the help of a customer support technician on
the telephone. If the most common corrective steps fail, you can always
use the restoration disc to recover your PC back to its known-good,
factory-fresh state.
SOURCE: IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
SOURCE: Ethernet driver
ftp://ftp.us.dell.com/network/R105478.EXE This is the link for the network interface card. Once you have this installed you'll be able to go online. Go to the Dell support website and download the rest of the drivers then.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? You need to specify the SCSI device to get a driver.
