Check to see if your phone is stuck in headphones mode. Clean out the headphone port if it is, and plug in some headphones a few times. iPhone 6 Can Hear Caller Fix
i just plugged mine in and made a call. it came in crystal clear and since they have noise cancellation as well you dont hear anything but who youre talking to
Bluetooth is a wireless technology that allows devices to communicate via high-frequency radio signals. Bluetooth headphones are just one of the many devices designed to work with portable music devices as well as ordinary phones. With Bluetooth headphones, you can listen to music as well as make and receive calls--all from the same device. Connecting them is a snap.
Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
I've read about this problem alot. The other people have resolved it by plugging in and removing a headphone adapter very quickly in rapid succession like 10 times. The problem is that your phone thinks there is a pair of headphones attached. You need to plug and unplug headphones quickly several times until the phone fixes it's glitch and figures out there isn't anything attached.
Not certain... but you need to check menu - tools - settings - general - enhancement and make sure your default is set to "headset".
When you plug headphones only (not the headset/mic combo) into the 2.5mm jack, it will go into a headphone mode where you can hear through the headphones but you must speak through the phone microphone - it sounds like it is going into that mode on you. It can only be the setting above or possible a short in the jack (though that doesn't really explain why it is happening only when you receive a call).
If you have 2.5mm headsets (or can pick up a small 3.5 to 2.5 adapter), you can also try having them call you and see if you can hear through the headphones - that would prove it is going into headphone only mode.
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine. Any help will be appreciated.
