As soon as I switch the washer on it trips the electric
SOURCE: hoover nextra keeps tripping electric
disconect motor and try again if still trips try pump,if trips again disconnect heater.This is prosess of elimination.
SOURCE: Tripping out.
Sounds like a brush prob to me.
Remove rear panel and remove motor to check carbs.
Replace if there is less than 2or 3mm left.
If it still trips after replacing carbs, then motor faulty.
Plz rate this solution.
Thanks.
SOURCE: Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It
seems to be the issue with the Thermal Fuse going bad and needs to be replaced.
It is mounted to the exhaust duct inside the
back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please
do rate the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
Testimonial: "Thanks for your quick response I will try and work out whch one it is and replace it"
SOURCE: hoover primera keeps tripping electrics when i turn it on
Short circuit in m/c. If happens when turned on at wall socket, probably mains filter, if when turned on at front, could be a lot of things, basically anything inside, would need it opened up to track
