The battery compartment is stuck and will not turn either way. Any tried and true methods??
On those old M series cameras its best to use a coin to unscrew battery cover. 10c piece is about right size. Right hand thread so anti clockwise. If its to stuck try a drop of anti seize or Penatrol, just a tiny amount and don't spray all over. Same if its corroded. If that is still stuck you can drill 2 small holes into the cover, insert 2 small bits of stiff wire and put a screw driver between them and unscrew that way. Replacement covers are available on ebay.
SOURCE: Can't open battery compartment.
ashe 1977
there are two ways to fix this.
1- remove the bottom cover, take the rubber seal off from the battery compartment, remove the battery then soak the bottom cover in vinegar overnite. this will remove all corrosion. remove the battery cap and clean the threads. completely dry the cap and bottom cover, apply WD40 to battery cover threads. clean battery contact with pencil eraser ( carefully ). reinstall the rubber seal, replace bottom cover.------ best fix.
2- this may not work but it's worth a try. just apply ( carefully ) WD40 around battery cap and let it set for about an hour, re-apply and wait another half hour. If this doesn't work refer to # 1
