Cars & Trucks Logo
C
Crystal Mullins Posted on Feb 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find the crank sensor on a 2009 Nissan Titan v8 truck?
Try to start the truck, it will crank but not fire, mechanic said it's a crank sensor but need it's location on the truck
jeff5may32
Level 3:
  • Nissan Master 1,258 Answers
  • Posted on Feb 17, 2015
jeff5may32
Nissan Master
Level 3:
Answers
1258
Questions
0
Helped
375533
Points
5289
I think it's the starter. On most nissans, the starter and the crank position sensor are close to each other. Some nissans have 4 position sensors, between crank sensor, crank angle sensor, cam position sensor, and sensor sensing sensor, oh and cam angle sensor. Oh wait, maybe it's a bad ground. Nope, gotta be the staerter.
Where can I find the crank sensor on a 2009 Nissan - 25440212-xipalmoknr3fbjmp51kycajc-3-0.jpg
2004 Nissan Titan stereo and wiring schematic diagram
OP Text edited for clarity and spelling
Audio Wire Color Codes for 04 nissan titan SE - Titan Talk
https://www.titantalk.com > threads > audio-wire-color-...
Jan. 9, 2009 - 2004 Nissan Titan Car Stereo Wiring Guide Car Radio Battery Constant 12v+ Wire: Yellow Car Radio Accessory Switched 12v+ Wire: Violet
Radio Wiring help 2004 Titan ' Nissan Titan Forum - Titan Talk
Jun. 20, 2019
Need wiring diagram for 05 KC ' Nissan Titan Forum - Titan Talk
Sep. 22, 2009
Wiring diagram for RF system 2015 ' Nissan Titan Forum
Sep. 12, 2016
More results from www.titantalk.com
2004 Nissan Titan Car Radio Wiring Chart - MODIFIEDLIFE
https://www.modifiedlife.com > 2004-nissan-titan-car-r...
Feel free to use any Nissan Titan car stereo wiring diagram that is listed on Modified Life but keep in mind that all information here is provided "as is" without any ...
I have a 08 Nissan Titan V8 it will start but not crank, any common problems with this issue
the problem is crank ( as in turning over off the starter ) but will not start ( as in continuing to run)
that would mean that there is a problem with the following systems
broken timing belt/ chain
crank/cam position sensors,
no fuel pressure / insufficient fuel pressure ---no fuel, pump , problem pressure regulator ,injector controls
ECM
ignition control module
immobilizer inoperational
try to get closer to the fault area by running the fault codes
2009 XF 4.2L Where is crankshaft position sensor located?
2009 JAGUAR XF 4.2L V8 Supercharged Auto Parts
https://www.rockauto.com/.../x,carcode,1442330,d,2009_JAGUAR_XF_...
RockAuto has parts for your 2009 JAGUAR XF 4.2L V8 Supercharged and all ... XF 4.2L V8 Supercharged Ignition Parts, Camshaft Position Sensor Crankshaft ...
Jaguar XF Crank Position Sensor - PartsGeek.com
www.partsgeek.com > ... > Jaguar Crank Position Sensor > XF Parts
Oct 1, 2009 - They are available for the following Jaguar XF years: 2010, 2009, 10, 09. ... 10 2010 Jaguar XF Crank Position Sensor 4.2L V8 Intermotor.
Images for 2009 XF 4.2L crankshaft position sensor ...
Nissan Titan V8
use the CD cleaner from radio schack or other computer store and clean it and fix it. Otherwise, you must go the repair shop for to examine inside mechanism and fix it.
God bless you
3helpful
3answers
Titan turns over but does not start
Titans have had an issue with a relay in the IPDM(fuse block), when I was at Nissan we replaced about 3-4 a week for the same problem.
No fire for 2004 nissan titan,replaced crank position sensor,throttle body(TPS sensor),spark plugs,fuel pump.
How about the high voltage coil, the high voltage wires to the distributor cap, the cap itself and the rotor inside. Any one of these could be the problem.
1helpful
2answers
04 Titan Does not stay on when cranked
if veh have malfuntion ligth on may be is the cranck possition sensor or the cam sensor, olso if there is no codes
is the IPDM ir intelylled power distribution module veh will cut off when running
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
