Question about T-Mobile Sidekick II
Why won't it charge??
My sidekick wont charge anymore when i connect the charger to it the light doesn't even come on ???
  • hhmommy Nov 12, 2007
    I had the same problem. The battery eventually won't hold a charge at all due to repeated recharging, and of course is not replaceable. My suggestion is that if your phone is still in warranty or you have the insurance try to get it replaced. Don't wait on this or you will be out of luck because the Sidekick 2 is an older model and you may not get any credit on your replacement if you wait too long. Next time go with a phone that has a replaceable battery. The Sidekick is cute and in style but once the battery goes it is a cute and in style piece of junk.
  • 3 Answers
I had a similar problem. I found that the charging port gets a little "stretched" after a while and the plug doesn't make contact the way it should when you insert it. I went and bout one of those universal chargers with the many different connectors and used one that is slightly larger in overall diameter with a slightly smaller hole. It worked fine after that. You can try wrapping the charger cord around the phone after you plug it in to see if it helps. It worked for me for a while but the charger plug eventually broke from fatigue. Hope this helps.
Posted on Dec 21, 2007
Orange light comes on but doesn't charge ?
There might be either problem with the charging point of the phone also try to charge using some different charger, if if does not work then require to replace the charging connecting point.
May 23, 2011 | T-Mobile Sidekick® 3 Cellular Phone
SiDEKiCK LX CHARGER PORT BROKEN??
sound like you need a new battery or charger or maybe both. try useing a diffrent battery and charger befor buying one
Aug 27, 2009 | Cell Phones
Sidekick lx will not charge
Try charging in using a different method, either an external battery charger or connecting to a computer.
Aug 09, 2009 | T-Mobile Sidekick
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick LX Wont Turn On !!
NO THEY PROBALY WONT FiX iT.....THE PHONE HAS WATER DAMAqE
Nov 02, 2008 | T-Mobile Sidekick
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick II Logo
73 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
