On my Nuvi 200, after "Where To?", you have to select "Address". My instruction book says: 2.Change the state, country or province if necessary. 3.Touch "Spell City", enter the city/postal code, and touch "Done". Select the city/postal code in the list. (Not all map data provides postal code searching). If you are unsure of the city, touch "Search All". There are further steps, but "Depending on the version of maps loaded on your nuvi, the button names can change and some steps could be ordered differently".
When encountering errors such as "No Map Data Available" and Garmin Express does not recognize your Garmin nuvi, check to see if your Garmin nuvi is out of storage space from your computer. Solution related to the fact that when brought up as the E: drive in windows there were 0 bytes free space on the Garmin nuvi. To get Garmin Express to recognize a unit which is full, do a search on the Windows Drive (E:) for "gmap" then choose "Open file location" This will get into the hidden ".system" directory. From there, delete the largest file map, such as "gmapprom" (or move this file to your hard drive). Afterward, reboot your computer to have Garmin Express software recognize your Garmin nuvi. On older units, also purchase a microSDHC card to be able to store the newest maps, such as the US & Canada 2.6Gb map file, which will not fit on the internal unit alone or a 2Gb card. The Garmin Express software will recognize 4Gb to 32Gb microSDHC Class 10 or UHS-I cards formatted to FAT32 and install the newest maps automatically to them. Some have reported that 4Gb cards are not large enough. I had used a 16Gb SanDisk Ultra PLUS UHS-I card ($10.88 Walmart) successfully on my Garmin nuvi 1450LMT
If you are having problems finding a particular address, try some of
following tips. In some cases the address may be listed as being in a
different city other than the one that was chosen. When the unit asks
for the City Name, try choosing Search All Cities. If the address is
listed under a different City Name, doing this will allow the unit to
find the address. Also, when entering a street name, it is important
that you leave off any direction or label. For example, if the address
was 2536 SW Melrose Place, you would enter 2536 for the house number and
only Melrose for the street name. Using the house number and
city/state, the unit will fill in the direction (SW) and label
(Place).
If you are still unable to find the address, the
mapping may not have the address available yet. Please report this to
our Cartography department using the Error Report Form which can be
found at the following link: http://www8.garmin.com/cartography/mapSource/errorForm.jsp
Instead of entering the city, press "Search All." Then enter the rest of the address. Sometimes the address is listed as being in a different/nearby city due to the ZIP code. Let me know if this helps.
Instead of entering a city, hit "Search All". Then enter the rest of the address as normal. Sometimes the address is listed as being in a different/nearby city due to the ZIP code. Let me know if this helps.
The signal or positioning of the GPS is not right sometimes it does shift you to other areas as it is planned to take that route for example:the next turn is left but you go straight and the GPS shows the car turning left.I think its something in the programming.
"You can search for a postal code. Enter the postal code instead of the city name."
Quote 2 (page 7):
"2. Select the region, city or postal code, when prompted.
Note: There never appears to be an occasion when I'm prompted to specifically enter a postal code, just a city. So I naturally do as instructed in quote 1 above.
