Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Battery recognized but wont charge
The computer recognizes the battery and states it is 77% charged. It, however, shuts off if unplugged and the charging light turns off a few seconds after the computer is plugged in. The computer works fine when on AC power
Not sure if it the battery or the charge circuitry.
Re: Battery recognized but wont charge
B olsun aldıgım icin lenovo berbat bi irmaau driverleinerde bunun lanet
Posted on Aug 11, 2009
I have the same problem.I bought a new battery but it still does the same thing.
Posted on Dec 19, 2007
    Problem Solver:
  • 9 Answers
It may be that you have a bad battery and you laptop may be reading it wrong since the battery may be bad. I recommend calling your pc manufactuer, and have the battery replace
you may go to or
for a look up on a new battery.
Hope this solves the problem
Posted on Nov 12, 2007
0 characters
3 Points
No battery is detected in dell 830
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 28, 2013 | Dell Latitude D830 Intel Core 2 Duo T7250...
Lenovo G550 battery shows fully charged but when you unplug the laptop, the laptop shuts down and will not start up again until power cord is plugged back in.
Shows a clear indication of the battery to be faulty. So in the first place remove the battery and checck the voltage, now keeping the battery off the laptop, plug the adaptor to the mains, Now checck the voltage in the battery terminals which is in the battery compartment. If voltage is present then the battery is bad as it is not charging.
However if there is no voltage then the main board has a fault in the charging section which must be looked into.
Oct 28, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My Kodak C913 has black screen when on and connected to computer with usb cord. Computer beeps indicating it recognizes something coming in but no dialog box to upload photos. Camera screen stays black...
dear sir,
your first suspect should be your battery....kindly charge it for few hours and later on your player,also plz try connecting the device with some other alternate u.s.b cord,this may cause due to faulty contacts also....if you still face the same problem then this is the problem usually caused by virus and sometimes it might be software failure also, which causes some of the menu not tof unction,the only solution is to re install software from the nearest service centre of kodak,it also updates your player software version....
thank you.....take care................
Oct 05, 2010 | PC Desktops
Battery not charging yet, computer says it is.
possible the battery is dead and wont take charge anymore or you dc jack has been knocked loose on the motherboard.u can send this out to be repaired for around 80$
Apr 13, 2009 | PC Desktops
Problem with emachine m5124 startup
Take the battery out and unplug the power cord. Press down the power button continuously for a solid 30 seconds without stopping. This drains all the power out of the circuits and resets whatever invalid state your computer is in.
Now, leave the battery out but plug in the AC and turn on the laptop. If it works, turn it off again and insert the battery. All should be well.
Jan 25, 2009 | E-Machines eMachines Desktop PC
Toshiba A300. One month old. With the battery installed, when AC power is switched off or disconnected, computer turns off immediately. With no AC power, and with the battery installed, computer will...
The PC suppose to still be on warranty, so you can go and returned. When you bougth it, you need to charged it for a period of 12 hours. If the battery charging icons indicates that is charging, maybe the laptop terminals are not working and you need to take it to the store for that.
Aug 09, 2008 | PC Desktops
My lap top turns off *** soon as i remove the power cord.... its like my battery will not take charge at all.. the battery light flashes 2 green and one orange... its a dell 9100
Dell has problems with that motherboard not recognizing the battery or the adapter. If you get error messages about the battery not being correct or recognized, the board has issues.
If this notebook is always plugged in then the battery has shorted and won't hold a charge.
Best option is to try another battery. Another thing, if your system is more than a year old, the battery needs replacing anyway.
If you are going to use this plugged in, get another battery, charge it up and remove it.
Jul 25, 2008 | PC Desktops
My computer just shuts down on it's own. The model is Toshiba Satellite U200 - 161. Basically, it doesn't charge. So I've checked the charger and it works on a different computer. But it doesn't charge my...
Like you checked your charger on another computer, try exchanging batteries with the same computer. If the problem persists, you have your answer.
May 23, 2008 | Toshiba PC Desktops
The battery on my fujitsu siemens does not seem to be working..when i unplug the erm, plug, the computer just dies..shudnt it be able to run on the battery? how do i know if the battery is charged? and how...
actually once you open your computer, its automatically charging your battery,let it open for a couple of hours,if you have the manaul of your pc,its indicates there the warning ,that your battery is charged already,now after a couple of hours and still does,t work,you have to visit a near shop to check your battery and your pc
Mar 12, 2008 | PC Desktops
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
415 people viewed this question
Top Lenovo PC Desktops Experts
Jose Cada
Jose Cada
Are you a Lenovo PC Desktop Expert? Answer questions, earn points and help others
