Nothing
SOURCE: Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
SOURCE: LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
SOURCE: Hitachi projection TV does not power up
You probably have a blown 2kV capacitor and 2 amp fuse. Look for signs of black burning inside.
SOURCE: Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the
timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video
out, Q705, 732, 761 and other components on the C board, also check
Q218, 219, 220 on the A board. In addition, unit could be in IK
blanking, try turning up screen slightly.
shaun
SOURCE: Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
