Wireless security I have a netgear wireless modem which my pc informs me is not secure and can be got at by the bandits how do I make it securergdsBarry
  • miffa Nov 15, 2007
    job done
Go to Netgear's site while the modem is running, check the 'set up' or similar link, and that should walk you through the complete set up and encryption process. If you have a set of numbers, usually groups of three separated by a period, just put that in your search bar.
Posted on Nov 12, 2007
How do i set up secured network?
set-secured-wireless-network-netgear-800x800.jpg Set up a Secured Wireless Network on Netgear Photo is inappropriate for this article Submit
A wireless network is comprised of a wireless router, a computer (or other wireless-enabled devices), a high-speed modem, and a subscription to an Internet Service Provider (ISP). Netgear is a popular manufacturer of wireless networking hardware that allows users to set up a secured wireless network. In order to prevent unauthorized users from logging onto your wireless network to gain access the Internet, and in order to protect the data you transmit and receive online, you should change your wireless router's security settings to create a secured wireless network.
1 Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another
2 Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses:;; or Press "Enter" or click "Go" in your web browser after you have entered the address.
3 Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
4 Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
5 Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the route
Things You'll Need
* Netgear wireless router
* High-speed Internet service provider (e.g., Comcast, AT&T, Insight)
* Cable/DSL modem
* 2 Ethernet cables
* Computer
* Web browser
* Router address
* Router's username and password
Good Luck : ) ....
Oct 14, 2011 | NetGear WGR614 Wireless Router
I have a netgear modem from virgin media and i cannot connect it to my wireless printer, the printer asks for a security string, what is this and where do i find it????
That is the wireless security key. You can check it inside the configuration page of your netgear router.
You can access your router by doing the ff steps:
1. Go to using a browser
2. enter UN and Password
default UN: admin
default PW : password
3. once in, look for wireless or wifi configuration then security.
4. you can change the wireless security as you wish
5. save and apply.
6. use the wireless key on your printer and it should work.. :)
Sep 23, 2011 | NetGear WGR614 Wireless Router
Have I got security on my netgear
If you try and connect to your router and it is asking for a security key then it is secured however if you do not know your password then you will need to reset the modem "Below is a link to show you how" The link under it will show you how to secure it.
Oct 29, 2010 | NetGear WGR614 Wireless Router
Connected but unable to view website
You might need to check the security on your router , if its enable or not.
You can try the solution below to check your router wireless security. Note this should be done on a computer that is connecting to the internet thru the router.
1. open browser and enter
2. username is admin , password is password.
3. click on wireless option .
4. look for the wireless security settings.
If you dont have another machine that is connecting to the internet. Just follow the steps below.
1. Reset your router for 30 seconds by holding the reset button.
2. turn off for 30 seconds after resetting it.
3.Power off the modem and turn it back on after 2mins.
4. If all the lights on the modem is stable power on the router, make sure the modem is connected to the internet port On the router.
5. check your computer which has a usb adapter,. Look for the wireless icon, You should be seing an option were in it will allow you to view the available wireless,
6. Look for the wireless name "netgear " and press connect. CHeck if you have internet.
Rate me if the solution is helpful
Kevin angell.
Jun 14, 2010 | NetGear WGR614 Wireless Router
Hi, I have a netgear DG834G version 3 wireless router. I want to buy a wireless printer, will this router support one? If so, have you any opinions on the best buy? Thanks
any wireless printer should and will work with this modem-router as long as it's wireless settings are configured right, if you already have a computer connecting to this router wirelessly then that means the wireless functionality of your router is working. you just have to know the wireless settings of your router such as the SSID or the wireless network name, the type of wireless security and the wireless security key or encryption key.. once you have a wireless computer and it wireless feature is enabled it will automatically detect all networks name or SSIDs around the area, that includes your modem-router's and neighbors'.. when you try to connect to the SSID of your modem-router you will be asked for an encryption key or a password to be able to connect.. that will only happen if you have enabled a wireless security on your modem-router.
Jan 30, 2010 | NetGear DG834G 802.11G Wireless ADSL...
I connected my new netgear as per the cd, and now it's not going into wireless mode, I still have to plug my ethernet into the computer to get networking... None of the DSL, Internet or Wireless lights...
you have a modem /router setting page if you ring your isp give them your model number they will tell you how to check your router settings it will load up in internet explorer for you 2 veiw
Aug 04, 2009 | NetGear DG834G Router
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
Netgear WGR614
after you set up a paaword to your modem. your PC cant recognise the modem anymore.
you need few setting for it
1.go to network
2. find your own setted upnetwork name
3. right click on it
4. properties
6. now choose your password options
most common one ise
your password (the one you set up to your modem )
allows only you to access
hope this helps
Nov 23, 2008 | NetGear WGR614 Wireless Router
How to enable router security system
Wireless security is difficult to handle simply because the manufacturers have different interfaces to the management software. Netgear has a very good description of how to set up the wireless security in the manual, if you have misplaced the manual it can be downloaded at:
Any posted answer would be multipages long and simply a rehash of the manual.
I recommend using the WPA-PSK.
If you have specific questions they can be answered quickly.
Sep 23, 2008 | Computers & Internet
NetGear WGT624 Wireless router
Check the security settings in the router . try in your browser and check the access/security. Alternately reset the modem using button on back next to Ariel and press for 5 secs. Your computer firewall may be a problem or there may be an address conflict with your other modem.
Jun 28, 2008 | NetGear WGT624 Wireless Router
Open Questions:
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
