Mechanic has told me the alternator needs replacing
Im assuming the alternator your replacing is on a v6 statesman.
1.disconnect battery
2.remove engine cover
3.remove drive belt
.remove 10mm bolt that holds bracket from eng to alternator
4.remove all wiring from the rear of alternator.
5.remove the 2 bolts that holds the alternator to engine.
6.wiggle alternator and it will slip out.;
7.refit new alternator in these steps but reversed.
8.once up and running again please make sure you check the system charge rate..
