Burners will not come on
Check the roll out switch it is located right in front of the burner assembly it will have two wires on it some times they are resat-able if you have to reset it do so and then put on the heat to see if flames are coming back out to trip the roll out sensor. make sure the heat exchange and burners are clean.
SOURCE: I get a flashing light
I will advice you replace the fuse on your heater and see if it will produce heat.
SOURCE: goodman model pgb030075-1 unit has led flashing on
maybe the exhaust fan is not getting power, here is a website that should help, Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
SOURCE: i have a goodman model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
SOURCE: I have a Goodman GMH95/GCH9 furnace. The blower
Hello, you can check the resistance of the motor by turning power off to the furnace and disconneting tje two wires which go to the motor. Take a meter and check the resistance, you should have resistance, if not the motor is bad. A rollout switch is a normally closed switch so you will chevk its resistance aswell, if the switch is open that signals a problem with the burner flames and you not read resistance. If the switch is closed and good you will read resistance.
Testimonial: "very helpful and fast response"
heatman101
