Question about RCA D52W19 52" Rear Projection Television
Rca d52w19byx1 cable in coax nipple brok off when my wife moved tv. i have taken back off and see the part that needs to be replaced but don't know how to remove or what the part is called.
    Genius:
  • 1,030 Answers
As a television tech i see everday.. the connector called rf connector.. sometimes u can replace the connector but unless your handy withsolder iron. it can be hard.. that connector is hooked to a part called a tuner..even hard to remove from that board...
Posted on Dec 07, 2007
  • Willie Howell Dec 07, 2007
    or simply run it through your vcr to another input vid 1
You could get away with replacing it if you get a 'freeview box' and connect it to the scart socket on the back of the tv and then connect your ariel into the freeview box instead.
Posted on Nov 13, 2007
The coax cable nipple (labeled "RF") on the back
As long as it was a clean break this will be an easy fix. If the tuner got damaged at all, then you will need to replace the whole tuner, which can be a bear if it is a two sided board. You can buy a new connector at just about any electronics store. You will need a soldering iron, solder and wick for the repair. You might be able to just solder the original connector back on if the break is clean enough. You will also need to stick a wire or something like that in the hole to keep the plastic from melting shut from the heat of the iron.
Apr 11, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I want to connect dvd recorder to dish network solo dvr vip 612 that is split for two tvs.
Hey! This is Becki Barned, with Dish Network customer service!!! You may have already gotten this taken care of, but either way, here are some steps if you still need some help! How I imagine you have this set up, is that you have RCA cables going from the receiver to the main tv. In this case, you will want to take the RCA cables from the receiver to the DVD recorder to a port that says IN. Then you will want to have either coax or RCA going from the DVD from a port that says OUT to the tv. If you use coax, the tv needs to be on channel 3/4, and the DVD on an input. If you use RCAs, the tv will also need to be on an input, such as video 1 or 2. Good luck! Blog back if any troubles!! :) Happy troubleshooting!!!!
Aug 20, 2010 | DISH Network ViP 612
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Coax cable broke off my wife tryed to put back in the cable line with coax insert broke off there was connector on the cable line she just jammed the bare cable line into the hole where the coax...
Yes there is a possibility that something shorted... remove the cable wire and unplug for 10 to 30 min and try plugging back in and restarting the set. otherwise the tuner probaly would need replaced. something any tv tech can do. AT the shop we replace these conectors al the time. just depends how bad the tuner is damaged.
Mar 17, 2009 | RCA Televison & Video
Need part
(800) 575-9833 Acme EnterprisesACME-301 replacement for 215543 use this information
Jan 19, 2009 | RCA D52W19 52" Rear Projection Television
Coax that looks like RCA?
There is a distinct difference between coax and phono (rca) cabling. Coax, sometimes called RF, is a cable that carries audio and video at the same time, what we call a "modulated" signal. RF connections look as if they are threaded on the chassis of your TV or VCR etc. A lone "Phono" cable moves either audio or video, but not both at the same time, unlike coax.
If you are attempting to patch RF, your cable must be coax at both ends.  Hope that helps.
Jan 07, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
RCA D52W19BYX1
If yu can email me a location number for the capacitor and I will look up the part number for you.
tvtek (@) msn.com
Jun 24, 2008 | RCA D52W19 52" Rear Projection Television
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
BROKE PART OFF TV-RCA F32665
Hi, some of those units have whats called a "RF cable" running from the back of the set to the tuner, and some are directly spot welded to the tuner, you need to remove the back from your set and see if yours is a short cable to the tuner, otherwise you have to replace the whole tuner, check the back of your set and you`ll see on a sticker the complete model number, (few numbers or letters after F32665) this is referred to as the service model number and I can look up exactly what you need to change
Nov 28, 2007 | RCA F32665 32" TV
RCA D52W19 52" Rear Projection Television Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
