Question about Hitachi 50SBX70B 50" Rear Projection Television
Hitachi 50sbx70b i was watching it and it started making a crackly sound then justed went of what could be wrong with it. when i took the back of 5 lights light up then 2more then it turns off but wont turn on but the 120v green light dont come on.
  • 4,402 Answers
This update covers to the following Hitachi models and chassis
46UX50B/51K, 50UX52B/53K, 60UX54B/55K, 50SBX70B, 60SBX72B, 70SBX74B. All projection televisions using the AP73 & 74 chassis's From Dennis Viereck
Intermittent loss of Raster, On Screen Display, sometimes sound. BUT ALWAYS HAS HIGH VOLTAGE! Also removing power and reapplying it again restores operation.
THE PROBLEM: There is a lack of a secondary ground for the CRT Dag connected to each CRT board. You can identify this missing ground on the CRT board by locating two vacant pins on each CRT driver board near the CRT socket. The connector is named P801, P831, and P861 relative to each board. The pin nearest the socket is the ground pin in question. The pin furthest from the socket is connected to the cathode of the CRT.
OBJECTIVE: Run a separate ground wire from the "GROUND" pin on each CRT board to the chassis ground. You can use the circuit board mounting screw on the frame under the green CRT. See drawing below.
DIRECTIONS: Obtain 3 wires 10, 14, and 18 inches long. The wire is 18 gauge stranded with an insulated jacket. Attach one wire to each ground pin on the CRT socket. Choose the correct length of wire so that all wires will connect to the circuit board mounting screw near the center of the chassis frame.
EXPLANATION: The extra ground is needed if an internal arc occurs in the CRT. This energy must find a path to ground. Before, the only path to ground is through the signal ground wire on the RGB drive connector. This thin wire does not go directly to chassis ground and is inadequate ground for the CRT dag. If the energy level of the discharge is high enough it may corrupt the data flow on the data & clock lines or negatively effect the OSD microprocessor. Since electricity takes the shortest path to ground, the additional ground wire will route the majority of that static pulse to chassis ground quicker and reduce the possibility of corrupting operation of the OSD processor.
Posted on Jan 04, 2008
2 Suggested Answers
  • 4402 Answers
SOURCE: i have a hitachi 50sbx70b
sounds like either a tube is arcing or h.o.t is arcing.
Posted on Jan 29, 2008
50sbx70b made sizzling noise then quit
Sizzle cound be crt arching or hv transformer. look for burn marks on transformer on deflection board. unplug set and remove crt boards from the crts and see if set will turn on. if replace arching crt. expensive. not to be attempted by amature.
Jun 27, 2009 | Hitachi 51F59 51" HDTV Projection...
My Hitachi 50SBX70B wont stay on
i think you may have a bad flyback. i have an hitachi that did that and ha to change mine out.
Dec 28, 2008 | Toshiba 55H70 55" Rear Projection...
Please help need to watch tv
Well this gives you someplace to start!
Symptom: NO POWER
Cause: Q777,I901
Cause: E994,D724
Symptom: SHUTDOWN/OPEN E995,E996
Jan 29, 2008 | Hitachi 50SBX70B 50" Rear Projection...
My 50SBX70B flicks than lost the power
Symptom: NO HOR SYNC
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Jan 15, 2008 | Hitachi 50SBX70B 50" Rear Projection...
I have a hitachi 50sbx70b
Nov 12, 2007 | Hitachi 50SBX70B 50" Rear Projection...
Televison & Video Logo
235 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
