Back to:
Tags:
Emerson EWF2704 TV
Input select function... without a remote? (by 6 users)
posted by isssaaac on Nov 12, 2007
is it possible to switch the function/component of your emerson EWF2704 without a remote control? When I manually bring up the menu screen it reads as follows:
picture set
channel set
english/espanol
v-chip set up
caption
tv sound
when I go into the channel set option I can only add channels or block them which does not change the function of my television! please help if possible,
thank you,
cordially,
Isaac WIlson
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by bewarethehay, posted on Jun 19, 2008
i'm having the same problem except it's even stranger.
i buy a universal remote and it works with my emerson t.v for several months, then all of a sudden just stops working. replaced batteries, reprogrammed the codes, etc and nothing. i've allready bought 3 remotes. i just don't understand.
Comment by kevin_alaska, posted on Dec 25, 2007
Same type of problem as above. One twist, I have a satelite dish on this tv and the input channel for that being 73.
Comment by Guest, posted on Dec 15, 2007
no remote is it possible to use input function manually?
Comment by d mark b, posted on Dec 11, 2007
I have lost the remote for my Emerson EWF2704 and now am unable to change the input switch from cable to my dvd player. I have purchased a couple of different universal remotes and the input select button does nothing. I am able to turn the tv on/off and change chanels, but still am unable to change the input selection. Is there any solution?
Comment by Tina C, posted on Nov 20, 2007
I have lost the remote to my Emerson 2704. A universal cannot access the menu to change the INPUT functions. I also cannot access this part of the menu from the panel on the front of the televison. It allows me to access the Picture, Channel Set, Language, V-Chip, Caption and Sound menus. I cannot get access to the PlayStation or the DVD anymore - the VCR connects fine. Where on the menu do I find the Input menu, or where can I find a remote that will access this television? Much thanks!
tl.cooley@yahoo.com
Can you Help with these Standard Televisions problems?
Emerson EWF2704 TV
Must use two remotes to watch TV. There are no codes to...
Emerson EWF2704 TV
has little shine on the screen as it should, more than 2...
Emerson EWF2704 TV
i have a black line on left side of screen.any suggestions...
Emerson EWF2704 TV
Black vertical line on left half of screen..any...
Emerson EWF2704 TV
This model screen has become "washed out" to...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
