Question about NetGear MR314 802.11b
Cant connect to the using the router.
Im using an adsl modem which came with the package atm how ever I want to create a wireless connection, to do that first i need to get this junk of a router to connect to the net which it doesnt..
As its EOL which doesn't help much ppl at Netgear just shrugged me off. have called tiscali, who are a bunch of useless chickens when it came to giving out specific ports, so that i could use port fowarding. Can anyone tell me all the settings I need to connect? if it supported PPPoA it wouldnt have been an issue connecting to the net,
The settings used are:
VPI 0 VCI 38
MD5 Chap
PPPoA VC MUX
by my dsl connection as usual by any1 else,
J
  • _J_T_ Dec 16, 2007
    Thanks for trying to help 2bob, I am able to login to the router via
    192.168.0.1 which is no problem, the issue is that the built in dsl
    modem does not support PPPoA only PPPoE, PPTP and Ethernet apparently
    it can support PPPoA via an external modem. The router itself does not
    seem to read my modem sagem fast 800-840, as apparently Tiscali sent me
    a dial up modem o.0. So I am not able to bridge the two connections via
    network connections, I am out of Ideas and not phoning up my ISP to
    help...they are inadequately equipped when it comes to technical
    issues.
    any ideas? thanks in advance.
There is another option. Purchase a modem that does support PPPoA and PPPoE
Posted on Dec 16, 2007
  • 55 Answers
Usually the ip address of the router is 192.168.0.1 or 192.168.1.1. If you plug it in then go to start then run. If you type in there cmd and press enter on your keyboard it take you to a dos page (black backround with white text) In there type ipconfig and then press enter on your keyboard. The default gateway is the address of your router. If you type that ip address into your address bar when you open your browser it will take you straight to the router page. There you can confgure it. Let me know how it works out.
Posted on Dec 15, 2007
  • wezley paton Dec 15, 2007
    the password defaul for your router is username admin and password is either pasword or admin. Make sure you configure the password to something that you know so someone outside your house can't change it. If they do it's easy to reset it back to the factory defaults by holding the reset button at the back for about 10 seconds but that can be a hassle so make sure you do change it for convenience reasons
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting to internet
you need to configure wireless on router panel using the browser.
Apr 16, 2008 | D-Link AirPlus DI-524 Wireless Router
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
How to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Apr 03, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
ADSL light flashing!
what is used this router it is a adsl router or only router if this is only router then you have to connect your adsl modem then only its work properly .
Sep 03, 2008 | Computers & Internet
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wired one
if you are not able to connect through your main comp using wireless router...then first of all check the ipaddress of computer by..
start>run>type cmd>then type ipconfig in command prompt screen.check whether you get the ip address as 192.168...........and default gateway as 192.168........
if anything else reinstall nic card on your comp
Feb 16, 2008 | D-Link AirPlus DI-524 Wireless Router
NetGear MR314 802.11b Logo
186 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
