Question about Palm TX Handheld
Battery life. At times my TX appears dead and needs rechg., but there is no way it could have used that much battery. Frank
Re: Battery life.
Do you have wifi or bluetooth turned on? This drains battery.
Posted on Nov 12, 2007
0 characters
3 Points
Apperantly the battery went dead. How can I
you will need a number 5 torx screwdriver, remove the 4 screws in the back of the unit and then remove the back cover wich is now hold only by clips, be careful because the battery is glued to the back cover that give accsess to the battery! also you can check out this tutorial on youtube on how to take appart the TX!
Apr 06, 2010 | Palm TX Handheld
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 | PDAs
Got new Palm TX out of box (although it is actually a few years old, but was never opened). charged for 3 hrs, but as soon as I unplug power cord, it goes dead. Battery appears not to work. found another...
The batteries have a shelf life. So they can die just from sitting and not being used.
What you can try is charge it and discharge it a 'few' times (few can mean 20-30 or more or less) it can revive the battery.
Replacement battery's are cheap $15 and up. So if you got these free it is worth putting one in.
Mar 16, 2010 | Palm TX Handheld
My TX won't hold it's charge. I used to go for days w/o charging, now I'm having to do it daily and I never know if it's going to work.
The rechargeable battery has reached the end of its life. You can get a new one for around $20 from several online suppliers.
Feb 02, 2010 | Palm TX Handheld
The Palm TX handheld will not turn on. It looks dead. Maybe just the battery is dead. Where I can find the battery
I have a PalmOne Tungsten T5.
I'm not familiar so much with the TX, but does it not have a charger? I have to charge mine periodically.
Sep 29, 2009 | Palm TX Handheld
Books on Palm TX
I would be happy to help you in finding resources for this issue. There are many places to get ebooks from and based on now much memory you have on your device will tell me how many books I can help you put on there.
As far as the battery is concerned I can help in finding a replacement.
Thanks Frank Z.
Jun 24, 2009 | Palm TX Handheld
The T3 will appear dead until the battery has SOME charge. A totally dead battery, even though plugged into a charger, will not let the T3 turn on. You mention a previous charger problem. Could be a bad charger, or a bad battery. Check to see if the charging light is on on the T3 when you think you are charging. If it is not on, try another charger. If it is on, you may have a bad battery.
Sep 09, 2008 | Palm Tungsten T3 Handheld
Palm Tx keeps short circuiting
Glad you have solved the issue. Let me know if it flakes out again.
Aug 28, 2008 | Palm TX Handheld
Pocke pc keeps resetting
I have 2 camcorder batteries that are totally dead. No matter how long I leave them plugged in, they aren't coming back to life.
Everything has a life span and it looks like your battery has reached the end of its life. If the e405 works on AC but not battery, then I have to suspect the batteries are now duds.
Time to go shopping on ebay!
Mar 13, 2008 | Toshiba e405 Pocket PC
Palm TX Handheld Logo
115 people viewed this question
Top Palm PDAs Experts
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
