Washing machine my washing machine has stopped filling and goes through wash cycle with no water then half wat through starts to buzz and says check outlet pipe which i have done this does not resolve the problem pipes not blocked and raised above the line indicated
  • 139 Answers
This is most likely a problem with the supply.. Esepcially if you have self cutting taps ...They do clog yo...... Check to see if the water pressure in the pipes is good
dissconnect form the back of the machine and let it run in to a bucket......
Posted on Nov 14, 2007
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
Washing machines problems
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Dec 09, 2017 | Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Whirlpool Cabrio washer model WTW6200SW, when the wash cycle is started, starts filling with water, after roughly one minute the machine stops than goes into spin cycle, will spin for a short time than...
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
Nov 01, 2013 | Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Samsung washing machine ji453s
The ECU has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
