Unplugging it. magic focus three times.
Pretty common failure with rear projection CRT sets.
Sounds like one of your convergence amp chips have gone out.
You can buy the chips from several vendors, or kits.
Do a search with your model number and "convergence amp chips". Shop around for the chips as they seem to be getting cheaper as this type of TV isn't as popular as they once were.
I've picked up several used Sony and Mitsubishi sets for nearly free that had this problem..
SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
SOURCE: 61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
SOURCE: I have a Hitachi 60sdx88ba
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
