Question about Dell Inspiron 6400 Notebook
Touchpad problem i am unable to scroll up-down or side to side with the lines on the touchpad.what could be the problem ?
  • 1,601 Answers
Re: touchpad problem
0 characters
3 Points
How do I enable my scroll bar on the keypad??
I trust that you understand that scroll bars are only visible if more than 1 page is to be displayed. If you have magnified a particular page, the scroll bar may be outside the view of the screen - on the right side, Scroll to the left until you see the right border.
Perhaps you are referring to the touchpad.
The scroll feature on the touch pad is not visible. You enable the touchpad by tapping twice on the upper left corner of the touchpad. A lite will appear in that corner when the touchpad is ON.
Then the scrolling feature is enabled on the right side of the touchpad. Simply run your finger up and down the right side of the touchpad. For more information, refer to the User Guide here:
Dec 20, 2014 | Compaq Presario CQ62-219WM Notebook
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | PC Laptops
I can't get my Acer 5534 touchpad to scroll up or down. I can move the arrow, but when I go to scroll up or down it wont move and I get a small dark circle under the arrow. It has done it before but...
go to control panel and open mouse option, from here selct the "touchpad" tab,now you should see a line that display the name of the your hardware ( the touchpad name) and below there is a button named "advance configuration" or simply "configuration" or "setting" ecc. Push it.
From the new windows you can control a very large number of options ,not only you can activate scroll in two direction ,but you can also decide the dimension of the touched area interested in the action.
Feb 05, 2011 | Acer Aspire 5315 Notebook
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
Touchpad driver for Windows 7:
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba PC Laptops
Mouse doesn't scroll when you run your finger down the right side
Here is great article on your touchpad, probably just have to do some configuring, open a your touch pad utility in control panel, have a look at your scrolling settings.
my asus eeepc i use two fingers to active my scroll
Nov 09, 2009 | Acer Aspire One PC Notebook
Hi, my laptop mouse pad works fine but at the side and bottom where i can use it to scroll down the page wont work, can sum one tell me how to get it back again, thank you
go to the control panel > mouse and pointing devices > go to device settings tab > highlight the touchpad listed and click on settings > look half way down the list where it say "scrolling" click on that and make sure both vertical and horizontal scrolling is checked. If it is and the scrolling still doesn't work,
go to control panel > device manager > scroll down to mouse and pointing devices > highlight the touchpad and disable it > wait 45 seconds, then re-enable it > hit apply and ok. Reboot
Oct 01, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Finger scroll not functioning. Is there possible
This is a common problem with touchpads. You should update the drivers for the touchpad on the laptop manufacturer's website, or if you are sure you have the most recent drivers (You shouldn't be, unless you updated them yesterday) then try this:
Go to the Control Panel and click Printers and Other Hardware, then Mouse near the bottom. Since there are so many Touchpad devices with different settings this is about as far as I can help you here, there may be a tab on the far right side leading to more settings. You should poke around in here being careful not to change anything unrelated to Virtual Scrolling, or just Scrolling in general.
(Win Vista/7)
Control Panel -> Hardware and Sound -> Mouse
There may be a tab on the far right side of the window at the top.
Click this tab and goto Settings, if it exists. In the new window you may see several options, look for anything related to Scrolling. Mine shows "Virtual Scrolling". Click that, and make sure the check box "Enable vertical scrolling" is checked.
If you don't see any of these things, update your drivers and try again..
Jul 19, 2009 | Compaq Presario CQ50-215NR Notebook
Touchpad's scroll button not working
Download and install this driver:
Sep 10, 2008 | PC Laptops
Dell Inspiron 6400 Notebook Logo
120 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
