Televison & Video Logo
A
Anonymous Posted on Feb 16, 2015
How do i check str w5453a ic, and what are the other components besides str
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Feb 17, 2015
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007833
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the number of the STR; in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
1helpful
My Tv has blown the fuse, then replaced the STR S6708 IC, now 300V shows for the Pin-1, but it receives low voltage2.1v for the Vcc pinPin-9 of the IC, pls guide me
Before replacing the switching output IC STR, you have to check all its associated components on board, especially low value resistors, and zener diodes. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
repair procedure of STR based power supplies, and circuit diagrams are given. Just type in the STR number in the search box at the right side to get gathered related posts.
I need schematic diagram for sharp blue diamond in regulator stage regulator STR W5453A
Circuit diagrams of many popular brand TVs and other devices are given. Search the site by type in the "brand name" to your device; (Exclude the model number), or the "regulator IC number "in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
STR 6707 give output voltage more than 110 voltage of TV Onida model BLACK
Check it with load. If it shows more than 112VDC, the IC is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check all the related components at the SMPS section circuit, before replacing a new IC.
Hi! i have sanyo televesion, model ts21sf1k. the problem is no power. i replace the power ic regulator STR w6753. but still no power. no voltage out in power supply.
SMPS circuit is not functioning. Check and replace all the associated component to STR. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
VOLTAGE DROP AFTER STR.MAIN FILTER NOT DISCHARGE AND FUSE GONE EVERY TIME. I CHANGE STR & SUPPLY IC.
connect a series lamp for sefty to the monitor. start to disconnect the component from fuse ,line filter, bridge rectifier, filter capacitor, check the voltage at ic 12v also check pulse at str if not then check ic resistors capacitors,and replace if found faulty
TV won't turn on, standby light blinks seven times over and over
Hello
Seven continous blinks denotes that your Sony TV has some high voltage more than normal inside its final anode of your TVs picture tube.. When high tension volltage exceeds abve 33KV [33,000VDC], to the final anode of the picture tube, TVs microcomputer Ic will detect it and get it shutdown, to prevent it from further damages.
You have to check its power regulator section for this fault. Usually Sony TVs uses STR regulated power supply regulation in their TVs.
You must open the back cover of your TV, and locate the power regulator section, sometimes be as in a seperate board or in the main board itsef. Check for any loose solderings it it. As components in the power regulator system will heat up during working. As it heats up and cools down for several times, some loose soldering may occure in it, and is usual. It is difficult to locate the exact point of loose, and is risky too, as the power supply regulation side is directly connected to mains supply and will always be "Hot", so i recomends you to resolder all the points, especially the points of high watt resistors in it. Resolder the the STR legs also. Sometimes the STR itself may need replacement. If so go for the same number and type. This might retify your problem.
Normally Sony 32" TV has a working voltage between 125 to 140vDV, at the secondary side of the power regulator. It it exceeds this type of problem will occur.
Take all precautions we take when work with an electrical equiments. Keep chlidren away from you, and note even stand beside you when you do works. Keep an adult beside you as a precatiounary measure. As high as 27KVDC [27,000VDC] points are there inside your tv, while it works. Take care. Never use metal a metal chair. Ok
3helpful
In my tv fuse is blowing off immediately
Hello
If fuse blows off immediately, i means that there is a short circuit occured in your telivision. This can mainly due to some diodes or regulators inside your tv. An overvoltage, spikes, ie [sudden high rise and go low], in the supply votage in your home, could damage power supply regulator components inside your tv.
All Sony Tvs has high accuracy power regulating systems inside. It is an onboard assembly, usually take 1/4th of the area of the TV. In older Sony TVs, this section was built in with use of transistors of different types. But your tv is not so old, so its power supply system is built with an STR, an Ic meant only for power regulations. Normally it willb numbered STR S6707, STR S6703 etc; according th the working voltage of the main board, and screen size of the TV.
This STR may get shorted due to power fluctuations, or any other reasons. A I mentioned above this is an Ic look like small squuare biscut of about an inch in square, and will be black in colour.
The rectified main power supply is given to it via an SMPS transformer [Swiched Mode Transformer], and the Ic will swictch it on and off at the rate of sbout 25KHz or more, and this transformeres secondary voltage is used to power up the other part of the ciiruit board.
If the fuse is blowing as soon as the set is switched on, this Ic will be faulty [Shorted inside]. If you put an another fuse, it also will blow up due to short. It is not good to play with power supply system by doing this as it may harm to other components also.
You have done it I thinks. Here in India, we gets 220VAC as home power supply. Sony TVs used here have a fuse rateing of 250V 3.5Amps. If your household supply system voltage is also this you must put only this rated fuse. If it is 110 or 120VAC, the fuse rating may differ; and will go upto 6 to7 Amps. More than this rated fuse should not be used.
You just do one thing. Just open the back cover of the TV, locate the power regulator section, and chech whether any main rectifier diodes for leak. There may four of them. In some sony Tvs, rectifier stalks are used. Check it for leak. If thery are all good, measure the resistance across the main filter capacitor with a multimeter set in Ohms range. If the STR said above is short, the meter will give full scale deflection. Unsoder the STR and pick it out after loosing its fixing screws to the heat sink. Again check the resistance accross the main filter capacitor. It must sho a low deflection or no deflection at all. Never replace the STR with a new one as there may be some other faulty components in that section. Usually when STR fails, there are some Zener diodes, Wire wound resistor etc will also gets shrted. If you replce the STR before checking them for fault, the STR you puts in will get shorted as you swich on the set. It will take just 1/100 part of a second.
So check all the components related with power regulator system, and then only repace the regulator. Caution: Keep chlidren away from you while you open the tv. Never touch any part of the circuit board while power supply is there. Plug out from the wall socket each time you touch the printed circuit board. As your Tv screen size is 32", an approximate of 25KVDC [15,000VDC], will be present at the first anode of the picture tube while it is working. It is too dagerous to contact.
If you haven't through knoledge, skill and patience, never try to repair it. If you knows to follow its schematic digram, buy one book and follow the circuit.
Keep an adult beside you as you try to repair your set, as a precaution.
If you have any doubt, report to Fixya, they will give me alert. Ok
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
