Question about LG GC-151SA Compact Refrigerator
Cold box at the top of the fridge
Our cold box on the fridge appears to not work it freezes ice lollies but not fish or veg is it a freezer compartment or just a cold box
  • 473 Answers
This box is the evaporator which provide cooling for the whole fridge. They will only freeze things solid that are easy to freeze. Don't count on it being like the normal freezer.
Posted on Nov 12, 2007
Hi,my bosch f/f is freezing in the veg box and has a lot of ice under the last box in the freezer comp.What is the problem please?
In the back of your fridge you should see a hosepipe connected from the freezer's defrost water drain to the evaporating tray usually located on top of the compressor. The drain is blocked, hence you get ice on the bottom of freezer. The easiest way to clean it is to pull the hose pipe off the fridge outlet and clean the drain upwards with a piece of soft wire or electric cord or something similar. On my fridge (Bosch) I found the drain clogged with a kind of jelly like stuff. The other way to the drain is by removing back panel inside the freezer compartment but be careful, I sort of ripped mine off and broke plastic plugs on which it was fixed. Make sure you know what you doing.
Cheers Karel
Jul 28, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
GE Refrigerator cooling system problem
My guess is that you need more refrigerant gas. It may also have a problem with the auto defrost system for the freezer. You have a block of ice in the evaporator instead of clear fins for the air to pass through. Make sure the door is correctly closed and that the magnetic door gaskets are in good condition. Once those are fixed you can turn the thermostat to make the fridge a bit warmer. Another possibility is that the circulation fan in the fridge has failed. Cold air falls to the bottom which is why your veg is freezing. You can't work on refrigeration gas yourself anyway, so call an engineer. Correct diagnosis of the fault will be cheaper.
'<your city> GE refrigeration service'.
Dec 06, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
LG GC-151SA Compact Refrigerator Logo
267 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
