Question about Maxtor DiamondMax Plus D740X (6L020J1) 20 GB Hard Drive
Maxtor 52049U4 20GB hard drive jumper settings
I have the above Maxtor hard drive and the bios shows no primary master hard drive. I want to check my jumper settings. How should they be configured?
  • 1 more comment
  • Anonymous Nov 15, 2007
    There is no diagram on the hard drive showing jumper info.
  • Maxtor2 Nov 26, 2007
    It's set for J50. I have one hard drive so that sounds right. Could the cable be plugged into the Ultra66 controller card in the wrong slot? There are two connectors on the controller card.
    I also have a problem installing drivers for "PCI Mass Storage Controller." Could this be the reason why?
  • Anonymous Mar 15, 2014
    Do I place jumper ad master on hard drive if running two drives and using it as operating system
    New Friend:
  • 53 Answers
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Posted on Nov 12, 2007
  • Ryan Wilson
    Ryan Wilson Nov 26, 2007
    JUMPER DESIGNATION
    |J50|J48|J46|J44|J42|
    | Master/Slave | | | | | |
    | Only Drive in single drive system* | J | | | | |
    | Master in a dual drive system* | J | | | | |
    | Slave in a dual drive system | 0 | | | | |
    | Cable Select | | | | | |
    | Disabled* | | O | | | |
    | Enabled | | J | | | |
    | 4092 Cylinder Limitation | | | | | |
    | Disabled* | | | O | | |
    | Enabled | | | J | | |
    | Factory Reserved | | | | O | |
    | Factory Reserved | | | | | O |
    J=Jumpered O=Open *=Default
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
How the jumper setting is done for maxtor n256j50
If this is an IDE/PATA hard drive then the jumper settings are marked on the circuit board.
MA = master
SL = slave
CS = cable select
If this hard drive is the one installed on the Primary IDE controller the the jumper has to be set to Master. If it won't boot up then the jumper needs to be set to Cable select.
If this hard drive is a second hard drive and is connected to the 2nd connector on the IDE data cable that is connected to the primary IDE controller then the jumper must be set to Slave.
If this hard drive is a second hard drive and is connected to the secondary IDE controller and there is no other drive on the IDE data cable other than this hard disk the the jumper can be set to either Master or Slave.
If there is a CD drive on this cable too then the drives on this data cable then the jumpers on each drive must be set differently, they cannot be set the same jumper setting.
Feb 09, 2011 | Maxtor Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Bios setup cannot detected 500gb sata Maxtor
hy on your maxtor hdd you have a jumper configuration you have to put your jumper in the good configuration so your primaries hdd is the one that have the exploitation system and the other one you need to set it to secondary hdd
bye and good lock
Mar 06, 2009 | Maxtor Hard Drive
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Maxtor diamondmax plus 9 6y080l0
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Maxtor DiamondMax Plus D740X (6L020J1) 20 GB Hard Drive Logo
5,523 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
