Have never changed ink cartridges before and want to replace all four colors
If you have some cartridges that aren't empty, first make sure that the printer is on. Then press the Menu button and navigate to the Maintenance menu then select Ink Cartridge Replacement. Press OK. Make sure that the document cover is closed then lift the entire scanner unit (grip it on the sides). If the cartridge carrier moves, wait for it to stop.
Then squeeze the tab at the back of a specific cartridge and pull it straight up. (Have one finger on the tab and another finger or thumb pinching the opposite side of the top of the cartridge.) Prepare your new color cartridge by shaking it 4-5 times then open the bag. Remove the yellow tape from the cartridge without touching any other parts of the cartridge. Then insert the cartridge into that slot and press down until it clicks. Repeat this for the rest of the ink cartridges.
Finally, lower the scanner unit and press OK on the keypad to exit the maintenance mode. Wait for the printer to do its ink system test routine. Cancel any print or scan jobs that were in progress before you changed the ink.
I hope this helps. Pictures to go with the above description are in the user's guide starting on Page 177. It's available here: https://files.support.epson.com/pdf/wf2520/wf2520ug.pdf .
The ink cartridge carrier moves and stops at the loading
position unless the printer is busy.
