Question about Roper RAX4233PQ Top Load Washer
Tub wobbles I have a Roper top load washer. It was working fine until the other night. It started to make like a grinding sort of noise, when I opened the lid the tub was wobbling from side to side. What makes it do that?
  • 1 more comment
  • Anonymous Nov 22, 2007
    I have a roper top load washer, mod #al4132vw, it used to make a high pitched sound when it started spin cycle, now it just shakes really bad during spin cycle. Thanks for your help. cpitchure@tds.net
  • pitchure Nov 22, 2007
    I have a roper top load washer, mod#AL4132VW. It used to make a high pitched sound during spin cycle, but now it just shakes really bad during spin cycle. Thanks for your help. Chris
  • brodylemon Jul 31, 2008
    newer washer, but the tub violently wobbles. ive tipped it up on end to see if there were any obvious problems, and i didnt see any thing that looked broke , and all of the springs seened to be hooked up, but the motor and the drum holder brackets all mover relitivly easy when i wiggled them. im thinking its probably going to be a major repair job but i thought id see if anybody had any last ditch effort ideas that i could try first.
    thanks,
    brody lemon
  • 1314 Answers
SOURCE: washing machine
its supposed to its on shocks and springs so it stayes balanced that way
Posted on Jan 22, 2008
SOURCE: Washer stops half way through rinse
Did you check the lid switch?
Posted on Feb 18, 2008
  • 1314 Answers
check the lid switch on the washer loosen the two screws on the control panel end caps pull the control panel slightly forward and tilt on its hinges then you will see a connector under the panel it has three wires one is gray one is green i think the other is tan unplug the connector and put a jumper wire from gray to tan to by pass the switch lower the control pane and start the washer to see if it continues if it does replace the lid switch
Posted on May 24, 2008
JR JR
  • 116 Answers
SOURCE: empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Posted on Nov 30, 2008
  • 464 Answers
SOURCE: tub gets off balanced during the spin cycle and
need to know the make and model to help you. tks.
Posted on Oct 11, 2009
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
My washing machine makes a grinding noise when it is spinning. It drains alright and seems to work ok, but I`m afraid the grinding noise could lead to bigger problems.
Stone,
All owners are heading toward this issue. I feel your FAV6800A or FAV9800A is at the end of service lifew for the Tub Seal
If you open the washer lid and spin the Washer CCW and hear the noise (Outer Tub Bearing noise) then it's time to role up your sleeves.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800A top load machine.
Google this FAV6800A/FAV9800A Outer Tub bearing replacement to see what is involved in doing an Outer Tub Rebuild.
Good Luck
Mar 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Tub will not spin on spin cycle makes grinding noise when it tries to spin motor is trying to spin it
could be broken motor coupling. after checking and this is ok go on and check brake wich is on top of transmission.
Oct 10, 2009 | Roper RAS6233KQ Top Load Washer
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Grinding sound from washer
the pully is the drain pump they can go bad or may have somthing in it, pump is not bad to replace part us usually 40 -60$ , you could burn belt up and be forced to replace it also, but if you replace pump would not be a bad idea anyway belts are 20-30 $
Mar 30, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Grinding Sound
Sounds like the brakes have become noisy, just like in an automobile if they glaze over they start to squeak. This really wont hurt the machine but if you dissasemble the machine (or pay a professional at the most 1.5 hr labor since your washer is the best design and fairly simple to repair) and clean the brakes (basket drive assy) and the drum (part of the tub support)
Oct 15, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
74 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
