2001 Harley Davidson XL Sportster 883 Logo
Posted on Jul 08, 2009
Starts up and idles but cuts out bad and dies
Starts up and idles but cuts out bad and dies when you give it gas 2001 883. 1st time starting this year put new gas in tank and new plugs
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1001
Points
6
Could be the jets clogged if it sat all yr taake off carbs use a paper clip to clean the jets out
My Durango starts if I give it gas and stalls when I let off the gas won't idle, help what to look for?
My car dies when I let off the gas - CarGurus
www.cargurus.com > Questions > Dodge > Durango
CarGurusDec 5, 2012 - My car dies when I let off the gas - I have a 2000 Dodge Durango SLT, I bought a month ago. I noticed it had a slow start but it still started and ran fin... ... Also, the oil pressure was high until it could idle by itself then it was back to normal. ... sometimes if you give it more gas it stays running but now it won't ...
dodge dakota idling and dying - CarGurus
www.cargurus.com > Questions > Dodge > Dakota
CarGurusApr 12, 2011 - dodge dakota idling and dying - My dakota will start then idle down and die. I can pump the gas and it will stay running but if i hold the peddle down or . ... thatdies on me at stop signs and when I take my foot off the gas pedal. .... and truck pops..misses and runs like crap and wont stay on unless i give it gas, ...
Truck starts but won't stay running...?? - Dodge Dakota Forum
www.dodgedakota.net/boards/v8/4240.html
Aug 9, 2003 - 21 posts - ‎20 authors
98 accord idles rough, give it gas it dies
fuel pump, filter and ejectors maybe bad need to check those three
4answers
Cars start but 3 secons after the engine die
mcdevito75 here, 3 seconds after the car stars I'll bet the idle goes way high, if so the fast idle swith / motor could be bad. Or if the idle goes way low, it could be the air Idle, sensor/ motor going bad. Either way have your local repair shop run a scan and see.
4.3 L will not idel
check the Idle Stop Solenoid
Ford probe idle fluctuating
Sounds like you have bad gas. It can get strong mix of gas to give you the right idle, but when it has water mix, it will cause the car to fire like it should. This will then give you a low, rough, or just cutting off idle. Try mixing water remover in with the gas. You may have to drain the gas out or just drive it like it is until the tank is almost empty. Fill up with gas (from a different store) and you may want to change the plugs after the good gas is through the system. I'm not saying the plugs are bad, but there may be a lot of moisture beads from the water sitting causing rust.
11helpful
3answers
Engine is missing and shaking bad when idleing or driving slow
MY CHECVY ASTRO 92 ,,STARTS FINE IT JUST SHAKES WHEN IN IDLES IN DRIVE OR REVERSE..HAVE NEW WIRES AND DISTIBUTOR
2helpful
2answers
My '98 Camry won't stay started. I start it and it just dies not matter how many times I try it. If I leave my foot on the gas it runs but at soon as my foot leaves the gas it dies.
What you have is a bad Idle Air Control ("I.A.C.") valve. This device admist a precise amount of air to keep the engine running at idle. This is a common issue. Get a new one from a dealer, and you will be up and running fine.
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
