Already replaced priimary corona and main drive pcb 2 but still same problem
SOURCE: canon irc3220 error 246-0001
Hello tech. I am scratching my knoggin since I can't find an error 246 in the service manual and the Canon website had no such reference. There is however an E248 which I believe is a "bingo" for your problem (but after 20 years of copier B.S. I never say never to undocumented error codes). So I will presume it is an E248 and here is why. E 248 means the ID stored on the EEPROM of the reader controller does not match the ID of the SRAM pcb. In fact there is an article on the Canon support center website I am viewing now regarding this.The only way to fix this problem (according to Canon) is to formally involve their Engineering group by way of contacting Canon support group and have them escalate the problem all the way to the engineering group.You know how anal Canon is. But again there is some question about the error codes. I truly wish I could be of more help......my heart ,mind and time are on YOUR side. Good Luck member of the "copier hell " brotherhood! :-) I'll clear a paper jam in your honor!
SOURCE: Canon MF8180c
Issue: ERROR LCD: System Error E197
Solution: Verify/reconnect power cord to fixing assembly
The power cord has been disconnected from the fixing assembly.
Verify/reconnect the power cord to the fixing assembly.
SOURCE: canon IR 2200 error code E000002-0000
It's to do with the fixing unit (hot bit) left hand side. Make sure theres no paper **** any where near it. If so switch off then on.
If not it looks like there may be a fault with the fixing film or may just need the error resetting in service mode.
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
