Question about Kenmore HE2 Washing Machines
F-21 what does it mean?
Lights flashing around cycle select F-21 flashing.
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
Hi....i want to know the different types of fonts how it looks like in EPSON LQ300+II printer??????? and i want to know how i can change the font without entering the default settings?????? thanq
Press the Font button. Font lights should come on or off to show the current selection. Press it repeatedly to cycle through all of the available selections.
Here's the table, 1 means on and 2 means off and 3 means flashing
Font ' Font lights Roman : 1 1 Sans Serif : 0 1 Courier : 1 0 Prestige : 3 1 Script : 3 2 Draft : 1 3 Draft condensed : 2 2
Dec 10, 2010 | Epson LQ 300+ Matrix Printer
Ran Cleaning Cycle, lights blinking w/ F- 21min alternating
f-21 is a blocked drain pump.remove the bottom panel,if you have a shop vac get all the water out,you'll see the pump and in the middle there's a piece that you can turn and pull out,first put towels under and around the pump to catch any water that leaks out,turn the part slowly and with your shop vac catch the water with the vac,take your time and open it little by little catching the water with the vac,when you get all the water out twist the middle part out and clean the catch and feel around in the boot and the pump and make sure you have it cleaned out.stick the middle piece back in and start the washer or you can fill it with a gallon of water and put it into a drain cycle and make sure it drains,if it doesn't you cooked the pump and have to replace it,let me know what you find and next time send the model number.
Jul 25, 2010 | Kenmore HE2 Plus Front Load Washer
I have a duet washer that on the display is flashing F-21 what does this mean?
“F21” on display (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
Feb 13, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
Code error for O2 sensor?
Code 21 the check engine light will flash 21 times cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
Aug 29, 2009 | 1995 Dodge Neon
Vdc and engine check lights both on
under dash connect together the 2 green multiplugs. The CEL light (Check Engine Light) will flash. Slow then fast. Count the slow flashes then the fast ones. I.E. code 21 will give 2 slow flashes then 1 fast = 21.
let me know the code and I will diagnose for you.
Dan
Dec 04, 2008 | 2002 Subaru Outback
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Washing Machines Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
