Have tried turning it on and off, etc. Have had to remove drip tray and empty grounds but there was nothing in those areas
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
SOURCE: Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
SOURCE: I have a Saeco Talea. The drip tray will go up
Probably the touch pad is faulty. Before we decide that make sure the bottom touch area is dry and nothing sticking on to it.Can be check by removing the 2 screws underneath.
The worst case senerio will be the CPU which is not receiving the signal from the touch pad.
Testimonial: "Thanks for thinking about my problem. Seems like the touch pad circuitry would be pretty reliable. Usually my problem with Saecos have been leaks."
SOURCE: I was going through the decalcifying process and
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
SOURCE: Gaggia accademia displays empty grounds
HI
This is probably your solution.
http://www.fixya.com/support/t9715819-39_dregdrawer_full_39_message_but
