Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Fridge leak by water filter Fridgidaire
My water filer is leaking into the top compartment on the door. The fridge is less than 6 months old. What could be the problem? I tool out the filter and it is not leaking anymore.
  • 4 more comments
  • Anonymous Dec 07, 2007
    water filter in side by side is leaking
  • MANZAREK Mar 13, 2008
    I double checked the filter and it still has the O Rings. The fridge is still leaking. What does"tooling the filter out" mean from the last comment?
  • Anonymous Mar 31, 2008
    my fridge door doesn't seem to be closing tightly and i find the door open.
  • khristy Apr 06, 2008
    I Bougth a frigidaire fridge on 11/06 on 4/08 I start to have a leak on the water filter and when i saw the all area was getting on fie,.it was scary. I have the pictures to prove it.I called best Buy were I got the fridge last than 2 years and thay say to call frigidaire.I am calling and can nobody to talk.
  • Julie Clifford Oct 14, 2008
    Our Frigidaire side by side Professional Series is 3 yrs old and we bought it with the house we moved into 2 yrs ago. Ever since we've moved here we noticed when the water filter in the refrig side got to be about 3 months old (supposed to last 6 mos...$50 each!) it would leak water all over the refrig. Finally called a Sears tech out and he said it was a well-known problem with the 2005 Frigidaire refrigerators...if the home's water pressure is too high for the frig, it destroys the seals on the water filter, hence, it begins to leak water all over. $390 later...he had to install an in-line water pressure regulator on the water tubing of the frig. What a rip off! No more Frigidaire appliances for me! Now when the ice tray fills, it sounds like a loud knocking at the door!! Jeez!
  • prattsapplia Nov 12, 2008
    i have tried good Quality presure regulators, mfg's regulator nothing seems to work.i have converted some from new square style to older round style,but this does not solve issue with square filter(pure source 2). has any one had luck with this issue!?
  • 44 Answers
Hello, sounds like the o-ring for the housing that the filter goes into was damaged. You can get a replacement o-ring from your locale appliance parts wholesaler/dealer - OR if you have a really good locale "Hardware" store - remove the o-ring from the male part of the housing that stays in your fridge (pinch it between you fingers around the diameter and you should be able to get it out). They should be able to match it for you - If I recall it is a standard size. If you cannot find one right away you may be able to get it to stop leaking temporarily by getting some Sillicone O-Ring GREASE and applying it to the o-ring. This may stop the leak but I would still replace the oring when you can. Good Luck Dr. Know
Posted on Dec 23, 2007
There has got to be a better solution to this water filter leaking problem than a pressure reducer because there's to many people that have already installed a water pressure reducer recommended by Frigidaire (that has been discontinued because they didn't work) and are still having the same problem over and over. The only guaranteed fix is by-passing the water filter all together but that means no filtered water or ice cubes. I hope the Frigidaire people can do something because this is ridiculous.
Posted on Jan 07, 2011
Hi, I notice alot of people having trouble with leaking ice makers. I have an older refrigerator that had the same problem for years. Taking the ice maker apart and checking all seals did nothing. Then one day I had an RO (reverse osmosis) system installed under my kitchen sink. The water line to feed the ice maker was also hooked up to the RO system. I noticed immediately that the ice maker quit leaking. I asked the RO guy about this and the answer was very simple. My household water pressure was too high for the shut off valve in the icemaker. The RO system acted as a pressure reducer to the icemaker. Now you don't need to install an RO system to reduce water pressure. A simple inline pressure regulator will work. This regulator would be installed inline between the city pressure and the icemaker only. No need to cut down pressure to the whole house. I would strongly recommend having your household water pressure checked as a starting point. My city water pressure runs about 60 psi. This fix was done about 7-8 years ago. Ice maker has been happy ever since.
Posted on Mar 16, 2008
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
What would cause my fridgidaire fridge to leak water
Condensation from ice buildup. Unplug fridge open door drop towels. Clean fridge completely. When no ice left plug I and resume. If it has water feed check for leaks
May 31, 2015 | Refrigerators
Getting water down the back wall of fridge whether filter is in place or not.
Should still be under warranty? Pursue that route
It/s possible put a paper towel on back side of filter see if you can isolate where the leak is coming from. My guess is the filter isn't installed correctly.
Mar 18, 2015 | Refrigerators
Water leaking from the water filter inside top right of fridge when getting water on side by side fridgidaire gallery series. How do I correct?
If the filter itself is leaking then you will need to replace the filter, otherwise check the o-rings and lines going to the filter.
Sep 25, 2011 | Frigidaire GLHS38EES Stainless Steel Side...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
No wate coming out the dispeser
The plastic water resivoir in the fridge compartment is frozen. Need to locate the resivoir which is at the bottom of the fridge and by using a hairdrier, warm the plastic resivoir for about 6 minuites. Suggest you turn the fridge off while doing this. retry and dispence water.
Jun 06, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Our RFA70 - less than 6 yrs old, is leaking water from the top fridge - the condensation hole in the middle. have already cleaned out the hole for any blockages, any suggestions?
you have a blocked up drain in the fridge compartment
its not letting water go down the drain and is just letting water overflow
May 02, 2009 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
7,126 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
