Question about IBM ThinkPad T23 2647 Notebook
Setup eroor post eroor175
Re: setup eroor
There is a i2c EEPROM ( not the BIOS rom memory ) where the checksum of bios and settings is stored. It's often 24C01 or a member family 24C0X . A picture can be see at
There is two possibilities:
1 _ Reset notebook to factory defaults to restore default options of cmos bios setup. There is a hole on botton side, see the manual where is and how to reset it. Connect it "in circuit" with a i2c "in circuit" programmer ( see SPI ), for example PONYPROG interface to a serial from another computer and write the right checksum for other identical notebook ( same model AND same bios version ), also resetted to factory defaults.
2 _ Exchange the IC. If the firmware detect a empty IC there is A CHANCE that it reprogram itself. I was write "a chance" because this depend of version of bios. You will need a hot air desoldering station, often used for fix cell phones, PDAs and expertise, care and patience to do this.
I'm have a thinkpad t23 with same problem, when I resolv this I'll post more info about this issue.
Posted on Mar 30, 2008
    Problem Solver:
  • 6 Answers
Re: setup eroor
This won't fix your problem but did wanted to put my input. This error basically means bad bios. IBM suggestion is to replace the board but ofcourse that is expensive. Keep me updated on any solutions you find. Somehow you need to flash your bios.
Posted on Nov 12, 2007
0 characters
3 Points
How to skip bios setup
F2 is your BIOS Setup enter key?
As SOON as you press the Power On button, start tapping on the F2 key.
Tap in 2 second intervals.
You may hear beeps. These are Stuck Key Error code beeps. You know what they are now, so just ignore them.
The BIOS Setup screen goes by F-A-S-T. You have a very small window of opportunity. This is why you are tapping on the enter BIOS Setup key, as soon as you turn the laptop on.
In BIOS Setup there is an option to bypass the P.O.S.T screen.
For additional questions post in a Comment.
May 21, 2012 | PC Laptops
Hi ,
1st - go to your task bar and see if the sound is muted , there will be a red x going through it ,
2nd - go into your control panel and find the device manager , click on that and look for Sound,viedo contrllers and right click on the sound driver and go to prop. and see if there is a conflict , olease let me know if this works and what eroor code you recive ,,,,,,,,,,Roy
Sep 13, 2011 | ASUS Eee PC 701 Notebook
I have a problem in my cdrom(dell inspiron 1525) it is giving eroor code as 0148 while diagnostic.plzz send me a good solution other than buying a new cdrom
Sorry, the error code indicates IDE ERROR: status which means that your CD drive is bad or the circuit which controls it (the motherboard).
Aug 08, 2011 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
I cant windows to sart i put in my password and the screen goes x eroor occured then back to password screen then back to error screen
if you forgot your password for windows you can solve it by using Hiren's Boot CD
download it and burn it to CD
the boot from cd and goto password recovery section. there you'll see active password changer. follow the steps and you can reset your password
Zafar Toshmatov
Computer Expert
Feb 01, 2010 | PC Laptops
After diagnostic runned appear CODE Eroor OFOO 137 B Msg: DVDRW_4 what does it means, also I have not been able to set up my IPOD TOUCH 32
It means that when you were running the diagnostics the DVD ROM doesn't have a disc in it.
That's it nothing to worry about!
Jan 31, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
I have had problems finding a power cord that works. The original cord died and replacements give eroors
If you are not using a Dell Branded power cord, the system will give an error due to non-Dell AC adapters do not have the sensing circuit needed for the system to ID the adapter.
If you are using Dell Branded replacement AC adapters, then you most likely have a bad power connector on the motherboard.
Dec 19, 2009 | Dell Inspiron 1545 Notebook
Key to go setup
While restarting press F2 or Del key to enter setup
Jul 27, 2009 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
304 people viewed this question
Top IBM PC Laptops Experts
John mullen
 Mike M
Mike M
Level 1 Expert
Are you an IBM PC Laptop Expert? Answer questions, earn points and help others
