Question about RCA P52926 52" Rear Projection Television
52 rear Projection RCA-Convergence auot cycle not working?
Hi-turn tv on colours off-went to Auto converqence but does not work-just goes quickly thur but does not go thur full lineup up which should take several minutes-thanks John
  • 927 Answers
It's late but try unplugging TV from a/c outlet for 5 minutes,if no fix call factory authorized service center. Good Luck, God Bless.
Posted on Jun 01, 2008
Rca 52" projection image problem
Try this with TV off Press and Hold at same time ch- and vol - until TV comes on It should either let you into service mode or start convergence Automatically
Sep 25, 2009 | RCA P52929 52" Rear Projection Television
Hi I have a 52" RCA big screen tv that is only 3 years old however we turned it on today and it is showing some red blue and green lines and the picture is blurry
Hello clara7,
This denotes a convergence problem. I would suggest that first you enter the menu of your TV ad try to do an auto converge on your set, if this does not work I would suspect that the convergence ICs have gone bad and need to be replaced. I would suggest that you have a qualified TV repair technician replace the convergence ICs in this set.I hope this helps,Shuttle83
Jun 08, 2009 | RCA P52939 52" Rear Projection Television
Green auto convergence
The master convergence settings have to be close for the Autoconvergence to work. If they are not you need a technician to go into the service menu and adjust them.This is a long job and you can't do it yourself.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Convergence prob for d52w26 rear projection tv 52"
If the auto-convergence is not working then the convergence amp ICs are starting to fail. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
have convergence rebuilt........
Jun 01, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52" projection tv...d52w20
You could have a bad red tube or the socket on the tube may be bad; completely different from convergence
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
