Refrigerators Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The refrigerator freezes everything
I set the thermostat at 37 F, but the refrigerator insists on running at 28 F.
  • goliad Jul 08, 2009
    No, the compressor is not constantly running, but the temprature stays below freezing no matter what I set the thermostat at.
  • Mike Price
    Mike Price May 11, 2010
    Is the compressor running constantly?
Anonymous
Level 2:
  • Expert 173 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Answers
173
Questions
0
Helped
72311
Points
338
Faulty thermostat. Replace or keep lowering temperature setting.
1helpful
2answers
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
2answers
KURS24LSBS
More than likely a faulty thermostat - fridge tech required.
I have true commercial double door cooler box. The temperature stays around 28 degree if when I set it very low. it causing big problem for us because everything freezes.
If you mean by low you mean number 1? This would mean the thermostat is bad. Number 9 would freeze everything anyway. I'm leaning towards a bad thermostat. Email if you want a thermostat [email protected]
Refrigerator thermastat set to 37 degrees but registers at 28. Freezer set at 0 degrees but registers at -2. Frig/freezer do not feel that cold but vegetable bin (produce bin) in refrigerator is...
i have never seen the problem
my idea is the thermostat is bad. but won,t both of them be bad.
you try to check the damper motor swithch and damper motor
good luck
Produce is freezing in refrigerator
might need thermostat replaced. use thermometer at different thermo settings to see if any changes
Refrigerator is freezing things at low settings
The thermostat ???? Without knowing what the original problem was, I can only guess that this the original problem.The cold control is only as good as the devices circulating the air in the refrigerator. You probably have a damper control problem. Make sure the damper between the freezer and the fresh food sections is operating properly.
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Food freezing in the refrigerator side
hi! you already the solution of the food freezing problem.the cause was occurs because the thermostat was not duly calibrated..it recommended for calibration.
Top Refrigerators Experts
vince
Johnny 1000
