Any old password that i can think of it says to go to account.live.com but how if i carnt get in or or try the last password you used on it. but i carnt get in to do that. what should i do
Use another computer to login and check the outlook.com password works.
You need a live internet connection to login to a online account. Check on the surface your have this (triangle of bars on screen).
Then put in the full email name for outlook.com account and password. The surface 2 will check that it can login and validate this account, and let you in to the pc.
SOURCE: forgot password for my hp mini 110.
HI,
Let me show you, how you can clear the admin or any other user's
password in a Microsoft windows OS...
The name of the software is
System rescue CD...
Its an iso file you need to bootable from an iso file.
http://www.brothersoft.com/systemrescuecd-271525.html
making iso bootable
1. Burn the iso to a cd or dvd using any Image burning Software such as nero or ashamboo.
and boot from it
2. another way is to boot from the pen drive
Requirements : min:1GB
Method: Download the free software "Unetbootin"
From.
then format the pendrive using Fat32
and use the software to copy the iso file to pendrive
and boot from it
when booting
select the option resch32(scroll down the option to see it)
and
select accordingly
For
any further guidelines give a comment..
SOURCE: TOSHIBA NB255 FORGOT PASSWORD BLUE
Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck. Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck.
SOURCE: Windows did an automatic update to my computer.,
Bill:
I don't know why or how windowsLive would stop you from accessing your hotmail account... but, if yoou cannot get to hotmail.com or msn.com, then try bing.com . On the top of the bing screen you'll find a 'sign in' link. This sign-in is for all of the MSN services including hotmail.
If for some reason, you are unable to get to hotmail from any of these methods, I would download another browser, like Opera, Firefox, or Chrome...
I would also9 consider removing WindowsLive!
SOURCE: Forgot the password of the admin user account on my laptop
I know a website http://www.reset-windows-password.com there are a lot of softwares on it, you can download one to reset or remove your windows password. it is compatible with Windows 7
SOURCE: forgot Dell Windows 7 password
when forgot Dell Windows 7 password, get tutorial to reset password:
http://www.windowspasswordsrecovery.com/articles/password/reset-dell-password-in-windows-7.html
