AMAZON !!!
Hope this is helpful :-)
-Scott
Genuine Dell AC Adapter Power Supply PA 9 20V 4 51A Model PA 1900 05D
SOURCE: problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
SOURCE: where is the location of cmos battery on dell 2650.
pulling the battery will not help it is hard coded in CMOS you need to send it in or take it to a service center that can re flash it for you i do not suggest you re flash BIOS on your own because that could cause a bigger problem
SOURCE: i had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Testimonial: "thanks for the prompt response."
SOURCE: Dell Inspiron 1545 power adapter not charging machine
Just call Dell, don't take it back to Best Buy or anything (that's where I got my Inspiron 1565). They will put you through a couple troubleshooting items and decide whether it's the AC adapter went bad or if they have to replace your motherboard. It's all free since they have a 1yr hardware warranty.
SOURCE: Does the Dell Inspiron 2650 Model PP04L have Wifi
Hi jenralley, !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work. Thank you!" - paul7of9
"The "Specifications" do not show {Wifi Capability}.
There is a "built-in Mode," with built-in Network Interface."
"This is use for "Broadband Services." Telephone and DSL {Cable} Internet!"
Specifications
Base configuration
Good
CPU
1.6-GHz Pentium 4-M
Screen size
14.1 inches
System memory
256MB of DDR266 SDRAM
Hard drive
30GB
Graphics
16MB NVidia GeForce2 Go
Pointing device
Touchpad
Expandability
No multipurpose bays, one PC Card slot
Extra features
Good
Bundled removable-media drives
8X DVD-ROM and 8X/8X/24X CD-RW combination drive
Communications
Built-in V.92 modem, built-in network interface
Extra ports
None
Business suite
Microsoft Works 2002
Other features
None of note
Overall design
Average
Battery life (hours:minutes)
Average: 2:18
Weight (typical/minimum, in pounds)
Heavy: 8.3/7.2
