Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
No Power Hello there is no power to either the stackable washer and dryer,, is there a common fuse?/
  • jay93257 Jul 03, 2008
    sudeenly my washer unit has no power. Is there a reset button
  • redee2lrn Dec 11, 2008
    my washer has a 220 v plug and my apt doesnt have this kinda outlet is there an adapter i can buy
    Genius:
  • 1,224 Answers
Yes
go to your fuse box if 220 flip both switches if fuse engaged there will be like a red line or fully difused down to show that fuses has been triped
if 110 your going to be flipping switches alot cause 110 runs both motor and guages together and over power is usually the cause of this
220 circuit one 110 runs the guages and the other 110 runs the motor and heater core
also washer wont run with out the water being on saftey feature
Posted on May 17, 2008
Stackable washer and dryer is getting no power
dryer has power, washer has no button function, no power showing , although on same circuit...??? any suggestions from anyone..
Aug 27, 2013 | Kenmore 98702 Stacked Washer/Dryer
I have a frigidaire stackable washer/dryer model number FEX831CS0 an the washer works but the dryer is seem not to be getting any power
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
Dec 19, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dryer portion on my stackable does not heat up.
Hello there:
please try these solutions and keep me informed on how this is going for you ok
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Kenmore 88752 Top Load Stacked Washer /...
No power is there a fuse in the dryer. The power is ok. Could it be the plug? It is at my summer home it is a stackable purchased about 3 years ago. I don't have the model. It was purchased at Lowes
There is a fuse in the dryer, its called a high limit sensor. If the dryer gets too hot the high limit blows like a fuse and saves your house.
Make double sure you have proper power at the outlet before you tear into the machine.
Good Luck
Quentin
Oct 05, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer of stackable washer/dryer stopped heating... is it fixable?
yes tis unit is fixable the most common problem is one of the thermal fuse has gone bad.the heating element could also be bad.
does the unit still run and you just have no heat check the above items this should take care of you problem.
Sep 18, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Washer won't turn on
Begin by checking to be sure the outlet where you have the washer plugged in has power. you may have blown a fuse or popped a circuit breaker. If no power, either replace the fuse or reset the circuit breaker by turning it all the way off and then all the way on.
Feb 28, 2009 | Washing Machines
Neither my washer or dryer has any power on our electric stackabl
IT IS GOOD THAT YOU STARTED WITH THE HOUSE ELECTRICAL. I WOULD NOW CHECK THE POWER AT THE RECEPTACLE AND THEN TAKE THE COVER OFF THE BACK OF THE MACHINE WHERE THE CORD CONNECTS TO SEE IF MAYBE A WIRE IS BURNT OFF. I HAVE SEEN THIS TOO MANY TIMES TO PASS CHECKING THIS.
Jan 26, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
