Question about Whirlpool Washing Machines
Whirlpool washer slow to spin
HI, I have a Whirlpool LSQ9520LQ0 washer that intermittently spins slowly or not at all at the spin cycle. There usually is an electrical - burning smell associated with this, but some times it spins fine. This has been going on for a week and is becoming more frequent as time goes one. Any suggestions.
  • 210 Answers
I would check the coupler between the motor & transmission, the clutch , the brake . Check for clothing under the drum stopping the drum from turning this could cause the slow spin too. Hope this helps good luck
Posted on Nov 22, 2017
    New Friend:
  • 45 Answers
Yes I happens to work a lot with this type of machines. Normally when the spin is too slow the problem rises form a week voltage, motor winding too week for the velocity. I means that the winding in the motor might have gotten burn and weakened the winding to the point where when the motor ask for more voltage to spins the housing the winding heat up. That is why you smell as something burning. The system in this type of machines is not complex but tedious. If everything else work in the machine then it is the motor.
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
  • 185 Answers
SOURCE: roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Posted on Mar 26, 2008
  • 16 Answers
SOURCE: whirlpool top load washer model # LXR7133JQ1
it's the spin tube or the cluch cant take the heavy loads
Posted on Apr 20, 2008
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Posted on Jan 19, 2009
SOURCE: washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Posted on Apr 21, 2009
Whirlpool washer does not spin
Try taking some of the wet clothes out maybe to heavy
Jan 15, 2016 | Whirlpool Washing Machines
replace the clutch assembly you c an usually test your clutch by grabbing the side of the inner tub while it spins if it stops then you have a bad clutch costs about 29.00 for a new clutch but you have to be able toremove the transmission from the under side and reinstall the new clutch if your not able to do this call a technician
May 03, 2010 | Whirlpool GSC9455 Top Load Washer
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
264 people viewed this question
Dan Webster
Dan Webster
Sal De
