Question about Kenmore Oasis HE 27082 Top Load Washer
Washer beeping during washing - no code error - now it starts and with the lid open
Bought the washer August 4, 2006 - out of warranty - when you turn it on it goes to clean washer no matter what buttons you push - no error codes coming up on it - and last night I woke up to find it running with the lid open on the unit - unpluged it and went back to bed - my wife plugged it back in this morning and it starts running water and stops as it pleases with the lid open or closed - any suggestions other than throwing it out the door!
  • 2 more comments
  • TexAg Dec 14, 2007
    JSRock516 - I have same issue and wish to repair myself. Please forward instructions - model #110.706200. email is I inadvertantly posted as solution - newbie.....
  • Anonymous Jan 25, 2008
    I have the same problem. Keeps beeping with the cycle light switching off and on. Do you know the part number needed?
  • Anonymous May 04, 2008
    similare problem: washer beeps during washing; then the light comes on that says "clean washer, use bleach only". We tried that. Didn't work. It just stops in middle of cycle now. Only 1 1/2 yrs old!
  • sheva May 17, 2008
    Hello jsrock516,
    I have the same problem with my Kenmore Elite Oasis HE
    My model number is 11027082601
    Would you kindly forward part number and instructions to:
    Thank you so much!
This is to Jsrock516, I have the model 11027042603. Washer runs through cycles but sometimes will beep continously while flashing through each soil level light, during this time washer can not be stopped but will finish all wash cycles. Sometimes when starting the washer the dial knob lights will light up in a circle not where you select. I am confused if the part I need is the User Interface #8564372 $166.76 or the Control Unit Assembly #W10155109 $143.20 both prices from 05/29/08. I have a 15% off parts coupon and want to order the correct part. Reply here or email Thanks!
Posted on May 29, 2008
We had the same problem; I replaced the controller board and it fixed the issue. I also decided to add a surge protector to (hopefully) prevent this from happening again.
Wonder if there is someone at Whirlpool that would want to troubleshoot the issue?
Posted on May 12, 2008
Has anyone tried to just unplug the card and then re-seat it? I have a similar problem with a digital control panel on 4 year old Lady Kenmore.
Last year when this first begain I opened the control panel housing and re-seated all the connections. This seemed to correct the problem. Now this morning, a year later, it's come back. I will try the re-seating process again; this time with contact cleaner.
Posted on Apr 24, 2008
  • LenRTX Apr 25, 2008
    I cleaned the contacts but it did not improve the problem. Folder inside the control case led me to run diagnostics. Problem is in the contol board, PN 8526076 Rev B. Am going to try Apl Parts Depot this morning to see they have the part.
    LenRTX with upset wife and lots of laundry.
    Well the new control card did not fix the issue. I bought a new membrane switch front panel at lunch and will install it this evening.
    Parts house will take back the control card that I bought earlier today if the old card works with the new panel.
I had the same problem, and jsrock's solution was the answer! Thanks to TexAg, who mentioned the clips...
FYI, it looked to me like if you bought the part from Sears, you couldn't return it. I bought it from another website that accepts returns, even on electronic parts, just in case it didn't resolve the problem...
Posted on Apr 23, 2008
I have the same machine with the same problem. Looks like the part can be ordered from Sears for about $150. I took the top off of the machine and removed the cover to the interface control board, but am at a loss for how to remove the interface control board. Anyone figure this out?
Posted on Dec 27, 2007
  • Phil W Jan 09, 2008
    Thanks jsrock and TexAg,
    Received the part from Sears yesterday and installed the new User Interface board in about 15 minutes. My machine works like new again. Very easy fix that would have taken two trips from a Sears repairman and several hundred more dollars had I not found this site.
I have the same problem. JSROCK516 - could you please give part number and instructions. Or email to Thank you !!
Posted on Dec 09, 2007
  • 1 more comment
  • TexAg Dec 09, 2007
    forgot the model # - Kenmore Elite Oasis Model 110.2706200
  • TexAg Dec 27, 2007
    Phil W
    I ordered the part from Sears website for $103. To remove the board, there are 3 (4?) clips that hold the board in at the top of the board. Just take a screw driver and gently pry to clip away from the board. Then just slip in the new board.
  • TexAg Apr 25, 2008
    You mentioned a folder inside the control case that said to run diagnostics. Hmmm, I cannot find this folder. DId you come with your washer or something you got seperate? Does it have a part # on it that I can order from Sears.
    Thanks - TexAg
  • 5,911 Answers
There has been a noted problem with the Oasis and the particular problem(s) you just described. The problem is caused by the User Interface board which is located behind the control panel. Make sure you identify the correct board. There is a Main Control board located UNDER the console. The user interface board is located BEHIND the console where the control knob and push buttons are. The only fix for this problem is to replace the control board in the control panel. If you provide me with your model number (located around the wash tub opening under the lid somewhere), I will research a part number and price for you. I can also give you step-by-step instructions on how to repair it yourself. Post back with comments and let me know. I hope this helps you.
Posted on Nov 12, 2007
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here--->
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine problem
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
stuck key or bad control
Nov 09, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he beeping during cycle
"HC" indicates hot and cold hoses switched.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
490 people viewed this question
Sal De
 Brian Main
Brian Main
