I have a Dell 1600n and recently started printing a vertical line down the center of the page. This occurs only when using the ADF.
You have either a piece of dust or a scratch on the scanning glass. This will show up as a line because the paper is pulled across the point.
A line appears every now and then on mine and only when using the ADF. I have been able to get rid of it by cleaning the ADF scanning **** glass with windex and a fair amount of pressure
This article provides the self-diagnostic
steps necessary to evaluate top-to-bottom streaks that appear when
copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
Think of it this way:
Suggested Diagnosis and Fix
Step
Action
Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
Perform a visual inspection for any of the following recurring culprits:
Other Possibilities
If...
Then...
Vertical lines appear only when printing...
Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
Vertical lines appear when you lay the page on the flatbed...
Vertical lines appear on ADF-fed printed copies, but
they do not appear on scan-to-network [e-mail, FTP, folder (PC),
solutions]...
Example the same probelm. Plust the toner rubs off the page.
